Talon R secondary battery
NemoDeven
NemoDeven
45
61
This box mounts on upper frame crossmember between front shocks worked out quit well. This is powering a winch and wet sounds 10 also installed with a isolator using factory installed winch wiring that runs to the stock battery so it will charge this second battery.
20190901 150048 20190901 150052 20190901 150106
Morris1219
52
24
Dallas TX
NemoDeven
NemoDeven
45
61
Looks good, is that a kit or just one you put together yourself.
Just one I built myself with 3" by 1/8 steel the bottom is 3" x 7 1/2" then the 2 end sides are 3" × 7 then back was 3" x 7 1/2" the I welded two studs to for mounting. The front has two 1" by 1/8 thick straps cut 7 1/2" in length
NemoDeven
NemoDeven
45
61
Fits the Oddessy Extreme pc680 battery perfectly.
