P1000 Race driven brake pads
GlockMeister
GlockMeister
The Bearded Wonder
7,604
35,567
Greenville, Mo
On the left is an oem brake pad with 2500+ miles.
On the right is a race driven brake pad with 350...maybe 400 at the most miles.
Needless to say im not impressed. The race driven pads are half of the oem....bit if they wont even last half as long guess ill go back to oem.
20190413 223829
Looks like I’ll be changing mine again after Takeover at this rate! The next trip will be Moab and I should prolly have good brakes there!
GlockMeister
GlockMeister
The Bearded Wonder
7,604
35,567
Greenville, Mo
Yep...my fronts are in better shape but i just ordered OEM from RMATV for 133 bucks.
Reactions: sharp, JTW and BWAF
ToddACimer
ToddACimer
Pioneer 1005-2
3,555
14,582
Oshkosh, Wi
Are these front or rear pads that you're comparing? In my experience the rears wear a lot faster. Still, I got 900 miles on my rear Racedriven pads
Reactions: Plumber32 and sharp
Ragnar406
Ragnar406
The Great Bald One
4,447
17,022
Bella Vista, AR
I changed my rears last July and just had to change them again - my rear pads looked about the same but for $35 I put the same back on....
GlockMeister
GlockMeister
The Bearded Wonder
7,604
35,567
Greenville, Mo
This is the rear....the fronts still look good.
GlockMeister
GlockMeister
The Bearded Wonder
7,604
35,567
Greenville, Mo
My rears were squeeking at 900 and fronts looked great. Honda probably should have put bigger pads on the rear of these machines
Agreed...i went ahead and ordered another set of the RD to hopefully wear down the fronts. Then will switch back to oems. My oem pads wore pretty even front and rear
ToddACimer
ToddACimer
Pioneer 1005-2
3,555
14,582
Oshkosh, Wi
I did the same thing. I ordered all 4 thinking they wouldmwear the same like the OEM pads but the fronts were perfect. Now I have a new set of RD rear, front RD with tons of pads and a set of each in the spares box. Maybe somebody else will come out with another option in the mean time.
Tundra20
Tundra20
316
811
Arkansas
I only got 100 miles on mine but will be doing all the work on the rig myself they hard to change out ?
I really like using the paddle shifter to down shift seems it will save some wear on the pads
0
0860silverado
945
1,813
louisiana
At 1200 miles, my front pads were toast and my rears were about half worn. I was really disappointed, thinking that I'd be ordering and changing brake pads with every oil change. I replaced them with the same OEM pads and now have about 5000 miles on them (6200 on the machine) and they're not squeaking yet. Maybe Honda installs cheap pads to keep price down? Or maybe the rotors had a rough surface from the factory that has smoothed? Dunno, but I'm satisfied with Honda replacement pads.
Manwell
Manwell
803
2,439
I just installed the RD pads on my machine, 2600 miles from the OEM, they were probably 1/16” pad thickness or less. I’ll see how these aftermarket pads work out, very easy to change.
Reactions: JTW
GlockMeister
GlockMeister
The Bearded Wonder
7,604
35,567
Greenville, Mo
Wow...look who it is.. i would not reccomend the RD pads. I am going back with OEM
Reactions: JTW
