P1000 RAD Customs Seat Extenders
TxDoc
TxDoc
2,252
7,532
TEXAS 🇨🇱
photos.app.goo.gl
anyone have a link to a source on these mossy oaks? none available in a 100 mile radius and walmart doesn't appear to have an option to ship them. odd.
Is this the same item?
Reactions: Robobrainiac
someguy1313
someguy1313
242
523
SouthEast
yes! i believe so! those guys are killing it on shipping! but thank you for the source. (may need to reconsider)
FL_CrackerLife
FL_CrackerLife
219
1,018
Lecanto, FL
Does anyone know of the Rad brackets will work in the newer 1000-5’s? Their website says for models under ‘21.
Sent from iPhone using Tapatalk
P1K5Dave
P1K5Dave
2,334
8,711
Petoskey, MI
I doubt anything has changed that would make them not fit. Most sellers do this because they aren't sure.
What I'd do is contact him directly. If he doesn't know for sure, offer to be his test buyer.
PapasTrail
PapasTrail
22
66
Cabot AR
I ordered the RAD rear seat brackets version 2.0 that uses the existing P1K5 seat bottoms that just pop out and fit on the brackets. I’ve got a 23 P1K5 and they fit just fine.
IMG 6945
It took about a month to get the bracket after I ordered it and RAD doesn’t return calls or respond to emails which made me a little uneasy about my order, but they did deliver.
I haven’t tried the heated hunting seat, but the seat brackets make a huge difference for back seat comfort! I definitely recommend them! IMG 6944
P1K5Dave
P1K5Dave
2,334
8,711
Petoskey, MI
It looks like he built the 2.0 taller to keep about the same height as I've got using the RZR seats?
I kinda like the idea of using your standard seats. While they might not be quite as comfortable, it's cheaper and easier. I rarely have back seat passengers so that's the way I'd go if I was looking today.
<edit> looked at the site and it looks like they're the same height. That means your seat won't be quite as high as mine are with the RZR seats (which can be somewhat problematic for taller riders.) Looks like a good upgrade to give you the choice.
Reactions: ChadD
Jankyeye
Jankyeye
883
4,196
Tampa, Fl.
I ordered the RAD rear seat brackets version 2.0 that uses the existing P1K5 seat bottoms that just pop out and fit on the brackets. I’ve got a 23 P1K5 and they fit just fine. View attachment 443839
I haven’t tried the heated hunting seat, but the seat brackets make a huge difference for back seat comfort! I definitely recommend them! View attachment 443840
Do you store them under the seat when not used? If so how much rattle/noise do the make?
Reactions: TxDoc
Robobrainiac
Robobrainiac
2,706
9,361
I would like to see and hear from you how well and easy they store. Keep us posted!
Reactions: ChadD and TxDoc
PapasTrail
PapasTrail
22
66
Cabot AR
They do fit in the foot well and still allows the seats to fold down flat. I assume they will rattle a little bit but not sure how loud it will be. I’ll let you know for sure.
The clips on the bottom of the seat clip into slots on the new bracket and the front seat posts fit into the holes with the rubber grommets.
IMG 6962 IMG 6963
