P1000 Ram mount
Soaz1000
Soaz1000
167
915
Soaz
Did a search and couldn't find if the Ram mount suction cup holds up mounted to the lower windshield on a flip up windshield near the window leaver, and if they do do you have to use the extended arm to clear the lower windshield lip ? Also thought about mounting it in the cubby hole below the big warning sticker. My warning panel is filled up with switches so no room there.
I did see a picture of one mounted in the cubby but don't know if it was a suction mount . I believe that person has sold that machine and isn't on the forum much. Thanks for your input.
Reactions: TxDoc
Mark in Northern Iowa
490
2,190
Floyd County, Iowa
kramnella.wixsite.com
I mounted my ram mount on the left.
I know you asked about suction cup, but maybe it would work for you.
I replied in a 500 thread, but my mount is on my 1000-3.
Have a good day
bumperm
bumperm
1,906
6,787
Gardnerville, NV
I you use a RAM mount on the windshield, probably a good idea to put a sticker on the front side to protect things from UV.
Scoop
Scoop
5,174
20,449
  3. Talon R LV
@Backwoods has a few things to put on the front of a windshield. 😆
Vikes79
Vikes79
SKOL!
11,747
113,955
South Dakota
  2. Talon X4 LV
Not sure what your trying to hold, but I’ve never liked anything attached to the poly windscreen….shakes way to violently. I also don’t get the need for the 105” tablet etc either.
This is what I use to hold my phone in my SXS , boat, and my vehicle with the suction mount if I need it. My phone mostly is the radio. Might use it for trails time to time.
The ball is thru bolted so it won’t work itself loose.
Dirtstiffs-1000
Dirtstiffs-1000
1,666
6,065
hondasxs.com
I mounted the extendable Ram mount / Tablet holder on the upper - underside of the cubby. It will swivel the screen up and over the switches and right to left, if I choose.
Don't use the cubby and minimizes Tablet dust too. JMO. Cheers!
20241124 084727
20241124 084832
Reactions: -Bear-
Red500
Red500
6,130
66,327
Greeneville, Tn.
Like was already said, I think the hole buggy shakes too much for a suction cup to work.
Reactions: Hogwild
