P1000 Rat wire damage - pin terminal tool
camp10
25
California
Hi guys,
A barn rat chewed on a couple wires underneath the front seat of my P1k5. Now it turns over but there is no spark. Honda dealership wanted 7k to replace the whole loom, which I can’t afford. Can somebody recommend any pin terminal tools that I can use to pull the wires out of the plugs? Thanks for any advice.
IMG 1424
IMG 1425
IMG 1430
JenElio
JenElio
78,413
693,623
Loxahatchee, florida
Hi guys,
Something as simple as one of these should help. If that's the only place they got to it then I definitely wouldn't spend the money on a new harness. The hardest part when rats/mice get in there is figuring out what/where the damage is.
Good luck 🤞
Reactions: Fatsquatch
Tramguage1
Tramguage1
Texan
7,546
31,100
Somereset, Texas
  2. 1000 6 Crew
  3. Talon X
  4. Talon R4 LV
@Neohio
@Hondasxs
G
GolfCart
145
408
NH
If just the insulation is chewed through and not the wires you can use liquid tape to cover the chewed areas, then put electrical tape over the entire thing. Just make sure all exposed wires are thoroughly covered with the liquid tape first and the liquid tape has completely dried.
For the cut wire it looks like you could just connect the wires back together. I would solder them for the best connection, shrink tube, and cover it with electrical tape. The blue cut wire looks a little short but looks like there is enough there to solder back together.
Reactions: Robobrainiac
Neohio
Neohio
Beast of the East
21,575
91,576
Painesville Ohio
You are going to need a good set of crimpers and a small flat blade screwdriver to remove pins. Think small, like jewelry flat head. I haven't depinned an ecm connector. @Hondasxs Might have pins available, or put together pins with 12-18" of wire extension on it.
500oneer
500oneer
15,000 mile club
427
1,083
Central PA
IMG 1457
My motorcycle had a mouse nest in it. My electrician friend was able to easily fix it for me. I should get some genuine Honda rodent proof electrical tape on it but it’s $50 a roll.
DRZRon1
DRZRon1
1,317
4,127
PA
Go on Amazon and search automotive depinning tool - many sets available - also for me - i used you tube to learn a little on it
StewB
StewB
754
3,495
View attachment 458222My motorcycle had a mouse nest in it. My electrician friend was able to easily fix it for me. I should get some genuine Honda rodent proof electrical tape on it but it’s $50 a roll.
A squirrel disabled my friend's 4Runner chewing the wires. The Toyota shop recommended the rodent tape.
It's expensive.
Reactions: 500oneer
