P1000 Rattles be gone..
A
arizonasteeler
23
40
mesa arizona
We finally took Whiskey out for the inaugural trail run. No trailering was required - we just loaded Whiskey with a cooler, Quad the dog, and headed out. The weather was great and the trail was a bit rocky. After a few miles in Bulldog Canyon, I noticed a few metal-on-metal rattles coming from Whiskey's bed and rear door latches. I tried adjusting the rattles out of the latches with a 10mm closed-end wrench, but still they were too much. I really like a quite ride. After arriving back home 30 some miles and a few hours later, I got to the task of working out the latch rattles. I've included a few pictures of the remedy that I stole from fixing a rattling door latch on our Ford super-duty few years ago. It was just a matter of a few layers of black electrical tape, and a couple rubber bushings I was saving from a previous project.
Nice pics, i been there many times with my RZR not with the new honda yet most of my riding has been in the peralta and superior az area so far looking forward to seeing you on the trails soon.
Reactions: peezul
Catdoz1
Orlando
I used heat shrink on the bed latches and door hinges. Worked great.
Catdoz1
Orlando
I cut a piece of heat shrink for the door latches and adjusted the bump stop put. I used 1" heat shrink double up for the bed latches.
IMG 7575 IMG 7576 IMG 7577
Reactions: JACKAL
Deer-hunter
Deer-hunter
136
200
Effie,Louisiana
For the bed latches I just adjusted both sides and the doors don't rattle if you close it fully. On mine if you barely close it it feels like it is latched but if you close it firmly there is no rattle at all. When some one gets in on the passenger side I know if the door is closed right within the first 10' of moving.
Reactions: TheHoover
Dasmoeturhead
After reading this I spent approximately 2 minutes wrapping the latches with electricians tape, and the rattles are gone. Will it last forever? No it wont, but the tape is cheap and easy to do. Thanks to the OP for posting this. It made me address this irritating problem. Wow! What a pleasant quiet ride. :)>
Have to wonder why Honda is overlooking such a inexpensive and trivial detail such as this. Nobody likes a rattling ride that sounds like it's falling apart.
Reactions: russknight
russknight
russknight
1,910
7,511
Perry Florida
My passenger side bed hinge rattled terribly at idle. I removed the hinge bolt and added a washer. That fixed it.
cntryby
cntryby
246
1,881
southeast
Adjusted my U bars, just need a slight push on the release lever to have the catch fully engage. Crazy rattles all gone.
JaceF8
North FL
Also to me. The doors need to be shimed on both side of the hinge like with maybe some washers to support them better and get rid of the wiggle
Can you show a picture of what you mean by this? I'm chasing rattles right now.
JaceF8
North FL
You adjusted the bed latches or the rear door latches? Either way what did you adjust? I don't see any adjustment other than the rubber stopper.
