P1000 Rattling noise
Js1039
Js1039
6
17
Louisiana
Ok I have a 2016 pioneer 1000 and it just start making a rattling noise from the engine area. Never done this before. Their are no lights on the dash board and it’s not smoking either. The noise stays the same idling or running down the road.
JenElio
JenElio
73,020
665,039
Loxahatchee, florida
First off.......welcome to the club 👍
We like pictures, or as they say......pics or It didn't happen!! 😄
So, could it be a rattling from a heat shield? Or is it more like the rattling when the engine is under rev'd in a higher gear then it's supposed to be??
Js1039
Js1039
6
17
Louisiana
The noise stays the same no matter if I’m idled or running wide open.
Reactions: Lady01
slowdryrider
slowdryrider
572
778
Canada
On my 2016 the clamp on the lower part of the exhaust header heat shield came off the shield causing it to rattle.??
Js1039
Js1039
6
17
Louisiana
Up on my bike. My kids ran it low on gas. And was going down the road and it just died out. And now it will not start. I changed the spark plugs. I did have the dealership fix the injector harness recall.
I’m not sure if I’m getting enough pressure from my fuel pump. It is putting out gas. Need help 🤦‍♂️
Reactions: Lady01
Jcdrury2s
16
47
Ok finally found the problem with my motor. The 2 bolts that hold the timing chain sprocket on have backed out and fallen off. So the cam shaft is not turning but the timing chain is
I think you have something else going on here, your bike wouldn't run if the camshaft isn't turning (opening and closing valves).
Reactions: HBarlow and Lady01
Js1039
Js1039
6
17
Louisiana
It’s not running at all right now. At first it was only making a rattling noise then it stopped running all together a couple of days later. Sorry for the misleading. So I order 2 bolts to put it back together
Reactions: Lady01
tdhanses
tdhanses
1,044
3,553
Kansas
Make sure you get the timing set right so you don’t damage the motor.
Reactions: Lady01 and Js1039
slowdryrider
slowdryrider
572
778
Canada
Yikes if the cam hasn't been turning and you've been spinning the motor over with the starter . I'm kinda thinking there's a good chance that you've got some bent valves and possible piston damage or bent connecting rod ??
Monkypops
Monkypops
Louisville
I'm glad you got everything going. I'm still having trouble wrapping my head around your fix for that problem, but congrats that worked for you!
Of all the motors I've rebuilt in my days, you are one lucky guy!
Reactions: Lady01
Ohio4x4
Ohio4x4
I brought the dishwasher
1,528
15,413
Ohio
Ok I hope this is the final post about my bike. I got the new bolts in and retimed the motor. Everything is running great so far. No more noise as far as now !
It sounds like you hit the lottery. I dont have that luck.
Reactions: Lady01
