P1000 RB3offroad A- Arm Bushing/Sleeves
RB3offroad
RB3offroad
1,702
4,753
Tempe, AZ
"NEW" at RB3offroad.com A- Arm Bushing/Sleeves - Front and Back. We machined them with self lubricating materials and added grease channels Which will help with the wear! Honda Pioneer 1000
2016 - 2019
Rsw600h600
farmtimpioneer
farmtimpioneer
Wise Men Still Seek "Him"
549
2,079
Brookville Ohio
Reactions: CumminsPusher
320,022
Ok, this maybe a stupid question? But I like to learn from Someone who has been there before me, what makes these better than the SATV A-Arms bushings, I just put A-Arms on, Thanks
I think the biggest deal is having a channel for the grease get in better.
Also those arms also seem to come with a few fittings that don’t accept grease so watch out for that
RB3offroad
RB3offroad
1,702
4,753
Tempe, AZ
All the Rb3 A-Arm bushings do come with grease channels(SATV - do not)for a longer life and the sleeves are made of SS with Zinc coating to last longer
farmtimpioneer
farmtimpioneer
549
2,079
Brookville Ohio
I did notice that the fittings on mine would take grease but it had no where to go once it got in the tube, so I pre greased the tube and bushing some before assembly, I can see where that could be an issue latter, the SATV ball joints will not take grease also, I had to pre grease the joint with a needle tip down the side of the boot seal, I will have to keep an eye on that and when them bushings do wear out I will try the RB3 bushings, I did get Your wheel spacers and door bushings they are Very Nice Work Great,, Thank You Very Much,,,,,
320,022
How do you know when you need new bushings?
Mine you could hear and feel but they were bad. Jack it up and shake your a-arms, look where any movement or sound comes from. Also check the sides make sure the plastic isn’t cracked or mushroomed in the sides.
russknight
russknight
1,916
7,542
Perry Florida
Will these fit the SATV arms?
