P1000 RB3offroad Replacement Door bushings
RB3offroad
RB3offroad
1,712
4,815
Tempe, AZ
Replacement Door Bushings are now in for your 2016-2019 Honda Pioneer 1000/700
Drastically reduces the rattling doors
Black Delrin
Comes in a set of 4 (2 Doors)
Check out our video on rb3offroad.com
Door bushings
Reactions: BWAF
Redmoon
Redmoon
265
456
Prescott Az.
Black Delrin
Just put a set on the new Pioneer. Worth every penny. took all of the play out of the door hinges. Adjusted the rubber door stop and now its exactly like you would expect from a new machine. Next it will be gasket to fill in the 1/2" gap around the doors.
ElmerFudd
ElmerFudd
64
120
Black Delrin
How do I get prices etc on these hinge bushings?? Had to listen to my Polaris buddy all weekend whine about rattling doors in my 3 LE. I fixed the bed latches by slipping a piece of heater hose over the latches. Does anyone make anything aftermarket for the holes large enough to throw a cat through on the doors??
RB3offroad
RB3offroad
1,712
4,815
Tempe, AZ
You can call me at 480-389-7486
Redmoon
Redmoon
265
456
Prescott Az.
Or just search RB3.com.
Trim-Lok D-Shaped Rubber Seal – EPDM Foam Seal with BT (3M) High Strength Tape System – Ideal Door and Window Weather Seal for Cars, Trucks, RVs, and Boats – 0.215” Height, 0.375” Width, 25’ Length
by Trim-lok
Search this on Amazon. I purchased the .53x.75 size after testing the gap on my cat just to verify size. Make sure that you get the BT adhesive backed gasket. BT is an industrial grade adhesive. Prep the area that the gasket is to be applied to by wiping it down with denatured alcohol.
Reactions: IrishLad
