BrianN
Ditch rider
Well, that just sucks.I checked other, I really haven't had a problem but I wouldn't call it perfect either. Seems a bit weak at times but can't really give an example. Compared to my P5 w an aftermarket unit the Talon is weak
I want to vote on this but I dont think my vote would really count since I haven't ridden on any trails in over a year. The times I do drive mine is from backyard garage to front garage just to warm the fluids up and keep the gas from going bad. Im all for any improvements on anything for the talon. Since I'm rebuilding mine I really only want to do it once and not to have to do it again. I have seen Raceco USA cooling system for the power steering set up. I scratch my head thinking is it worth doing or just more money to spend on something that isn't needed. Granted my steering box is stock since nothing aftermarket was out yet when mine broke in half. If its worth buying a better steering set up then I'm all for it. Ill keep watching this post to get smarter on the issue and to get feed back on what everyone else issues are with their steering.
Has anyone tried using a bilge fan on it? A bunch of us used them on the pioneer under the seat to blow engine heat out.
10-4. I thought u were moving it for heat issues.Heat is not an issue for the average rider. Before relocating the ECU, my PS sucked stone cold and made no difference as the day went on, even in 100 degree heat.
Now, if you are a racer or run super hard for extended periods AND find your PS actually fading/diminishing as it heats up, by all means, cool that sucker down. If it sucks when cold, adding a fan will not fix anything.
Background - Paul's theory is that the wire gauge is too small for the load of the motor and distance between the EPS ECU and the PS motor. He's moved the ECU up by the PS motor and increased the wire gauge. Initial results have been very promising.10-4. I thought u were moving it for heat issues.
I wonder if that is the issue, why not just increase the wire gauge size even more to avoid having to move the ECU? Is there that much power drain even with a larger gauge wire?Background - Paul's theory is that the wire gauge is too small for the load of the motor and distance between the EPS ECU and the PS motor. He's moved the ECU up by the PS motor and increased the wire gauge. Initial results have been very promising.
Paul gives his reasoning and a LOT of useful information here -I wonder if that is the issue, why not just increase the wire gauge size even more to avoid having to move the ECU? Is there that much power drain even with a larger gauge wire?
My test rig has a switchable bypass so I can set it low power (even in 4wd), normal or full power all the time. Because the TorqLocker does cause some steering stiffness, I have tried with mine bypassed to full power all day at the dunes and trail riding without any issues. It is the slow speed stuff that is problematic.IIRC, you previously mentioned that the computer allowed higher current to the PS system when in i4WD, and there was a way to bypass it for high current in 2WD. Did you have this bypass on during this ride, or were you always in i4WD?
Working on that angle as we speak.Anyway to put a/several heatsinks on the parts?
I saw that too. It appears the motor and ECU are combined into one unit. There are some differences in the u-joints and shafts too. As soon as my dealer has one on the floor, I will investigate and see how much better the pioneer is, what the differences are and if it is feasible to retrofit.I saw where the pioneer is getting the whole power steering system upgraded on the '22. Wonder if the Talon will follow suit. I haven't looked but imagine its close or the same parts between the 2.
My Pioneer steering sucked in the rocks when it got hot. I pulled both arm muscles every ride. Pretty much had to roll to get it to turn. 32" stickys though.I saw that too. It appears the motor and ECU are combined into one unit. There are some differences in the u-joints and shafts too. As soon as my dealer has one on the floor, I will investigate and see how much better the pioneer is, what the differences are and if it is feasible to retrofit.
What baffles me is the pioneer is not known for steering issues and the Talon is yet they upgrade the Pioneer??? Honda needs to do more consumer research IMO.
