P500 Rear Camera hookup
czrider
czrider
37
97
Maryville, Tennessee
Has anybody found the wire that gets hot when you put the 500 in reverse. ? I've checked all lines coming out of the dash while in reverse and had no luck. If I can't hook it up to a line when put in reverse I will need to add a rocker switch to activate it. Any ideas ?
906UP
906UP
14,392
136,726
da Yoop
You won't find a hot wire, it's a ground wire signal to the ecm that indicates "R" on the screen. @Hondasxs has kits with a relay for reverse lights that would work. I put a cam on the Talon but set it up so it's on all the time, use it like a rear view mirror.
czrider
czrider
37
97
Ok I'll look for the relay kit. Thanks
DDDonkey
I did the same on my pioneer, the camera really help with the rear seats up.
HUCK
HUCK
1,047
2,319
ARIZONA
Have you heard about the new eye activated one ? It's called a rear view mirror . Works awesome . 😂
  • Haha
Reactions: 906UP and J80
906UP
906UP
14,392
136,726
da Yoop
I've tried a rear view mirror in the P500 and took it out. Thanks anyway
Same here, I put one in the Talon for a bit but for me it's hard to get a clear sight out the back, besides the camera was cheaper....LOL
