This isn't a how to on the boot. There are plenty of those around.
Just want to let everyone know that if you purchase the All Balls brand for the rear outers, you will need to source an outer clamp.
The part # is 19-5025, rear outer. 19mm x 64mm x 95mm long.
Comes with boot, pack of grease, and 2 "tool less" clamps.
1st off, these aren't really tool-less clamps. These are the multi-wrap style that used to be marketed under the "Band-it" brand. They can be done with pliers and a screwdriver, but there is a serious risk of destroying the new boot if you slip. @CptOvo can show you how in a video on his channel.
I've used these before WITH the proper tool, and they do work, but require you cut off excess clamp, leaving a sharp edge. It can also be tough to keep the wraps in-line.
The real issue, however, is that the large side clamp is too small. A wrap will have to be removed and it enlarged to fit, meaning it has been taken out of it's designed state or operation. It would probably be fine, but given the somewhat fussy nature of these anyway, I'll probably drop by the parts store and get new clamps, or do as @joeymt33 says, and reuse oem (I have the tool for those anyway).
It has to be obvious...even to the person packaging the boot, that this clamp is too small. And a number of people complained about this in reviews I failed to read before purchasing, so its not an isolated thing.
Just be aware of this if you buy it.
In its defense, it's a whopping $12 on Amazon, so plenty of coin left for new clamps.
