Yes you can just remove the bottom bolts but you may need to pull the shock bolt too.
Wasn't a terrible job. But nothing (for me) ever goes as smooth as I'd like it to!
In the end, I tinkered around with it over the course of the weekend while stopping for frequent and sometimes long NCAA tournament breaks (Go UofM and MSU).
I got it together and had about 4 degrees positive camber. I made adjustments to both sides and did have to pull the shocks to get the lowers down to adjust. I ended up turning the adjusters farther out than I really wanted. I turned them all the way in, and then counted turns out to be consistent. I think I ended up turning them out 20 full turns! Didn't feel like there was a ton of material left threaded in. It still had some visual positive camber when I set it down, but after riding and letting is settle, it's about -1 degrees.
So next time I have a chance, I'll take a couple more turns out and hopefully get it straight. It does look a lot better with the tires nearly straight!
Thanks, Ragnar, for the approx on degrees per turn. That got me close quickly!
One question on the bushings. When I greased them, the bushings just push out. So I put them in the vise and clamped them back in. The grease came back out the check valve on the zerk fitting on 3 of 4 bushings. That bothers me a bit. The other one wouldn't stay together, so I took the fitting out, let the grease out that way, and put it back together.
I wonder if the grease is where it needs to be? I'm more use to grease coming out the other sides.....
Any thoughts?
Thanks all for the help!!
