I have the highlifter bracket lift, not sure if you do too but I have 3/4" threads showing. This is from adjusting out five turns from the way mine came in the box. This put me with a slight negative camber (1/8") which is what I was going for. I'll re-check after some miles.
If I had it to do over I would have greased them prior to installation like someone said above. Not the easiest thing to do once installed.
Yea. - I have the bracket lift too.
I turned them all the way in, and then back out using the degrees / revolution recommended above based on my measurement after the initial set up.
For some reason my passenger side shock is pretty tough to align with the control arm, so it makes the job a pain. It took some 'motivation' of the bolt to get it in. The drivers side is pretty easy and only takes a couple minutes to adjust.
I did grease them on the bench before the install. I had to then use a clamp to squeeze the bushings in before installing the arms. I question how much grease actually squeezes between the bushings and the arms. When I squeezed the bushings back in, a bunch of grease came back out the fitting. I guess time will tell if the grease is effective. If I wear out the bushings, I'll slot the next set like was suggested above.
