Talon Rear wheel hopping
DAJO
182
125
Indiana, Arizona
Went to Silver Lake Dunes yesterday. Have shocks set on soft and adjusted crossover rings about a 1/4" higher than they were from the factory. Tires set at 13 rear 11 front. When accelerating in the sand I am getting rear rear wheel hopping when spinning in the sand. Should I have tried setting the shocks to a firmer setting to stop this?
Never had a machine that had the power to climb all of the dunes before. First time over steep dune I slowed down to much at the crest and got stuck good. Two guys in RXRs came along and helped us get out. After that made sure to carry more speed and went right over every time.
Reactions: sharp
JimmyTalon
130
235
SE Minnesota
I would try more damping (higher shock damping setting). Also, lower rear tire pressure. With quads we ran pretty low pressure in sand. Without beadlock rims, you'll have to experiment carefully.
DDDonkey
I know my buddies at glamis run like 6 psi in he rear of there X3’s and never lose a bead, I would lower your air pressure.
Reactions: Plumber32
66,778
Definitely the tires causing it. Same problem with snow, but I am surprised the stock tires do that. Normally it's more aggressive tires do that. Was the sand heavy and wet?
DAJO
182
125
Indiana, Arizona
Thanks all you guys except JTW LOL.
The sand was wet and mostly smooth in the morning, rained during the night.
Reactions: JTW
P
Puller810
23
17
MICHIGAN
I had mine out there and lowered my pressure to 7 all the way around. Zero issue with wheel hop afterwards. Just be mindful of doing donuts.
