RECALL - Intake Bolt Recall for Honda Talon 1000 (19-21)
hdrews91
21
77
North Carolina
I heard about this happening a few weeks ago. I just pulled my air box off last weekend and snugged them down with a dab of blue loctite just to be safe. Only takes a few minutes to get in there and do that.
64,057
From what I understand.
Here are the 2 bolts to check. In this pic you can see it is fairly far out. Second pic is tight and the threads deformed to prevent it from falling out if it comes loose again.
82221d5ed2ac84c426a02a6766583a624552b37b626b4bad9fd18ed78585aa7e
stellarpod
stellarpod
821
3,024
OKC, OK - USA
hondatalonr
38
Arizona
Thanks SxS. So those just hold on the flared intakes, but would be be a disaster if ingested in the engine.
Someone on this forum reported clamp being loose and causing dirt ingestion ruining the engine. I assume they are on the other side of airbox. Maybe we should be looking at them also.
64,057
And might as well check the filter bolts too while you are in there.
3 have holds. 5 do not.
Dankathy
286
822
I had significant engine damage on a prior machine due to the tubes not properly installed on the throttle bodys. Different location, same sloppy workmanship/quality control.
64,057
I get why they did that to the ones closest to the air boots but at that point why not make them all captured? Seems dumb not to.
Looking at the manual.
It looks like the other 5 are blocked by the air box lid. If they come loose they can't fall into the intake without the lid being off.
PapaC
PapaC
55
334
W. Wa
Just checked mine. Bolts were tight, gap between band ends is under 10mm, but the bolt threads are not deformed. Wondering if I should let the dealer do it to avoid any possible liability issues, or if I should “take the bull by the horns“, and take care of it myself. What think ye all?
stellarpod
stellarpod
821
3,024
OKC, OK - USA
I wrestle with the same issue. Easy enough to deform a few threads. That's probably exactly what I'll do (once the temperature rises enough to keep my blood from freezing solid on the way to the barn...)
Steve
5,060
22,704
Steve
#metoo 🥶 🥶 🥶 My Talon is long out of warranty and as much as I hate opening the airbox, it's time I had a look 'in there' anyways. The Hondabob snorkel with a Uni pod prefilter has worked so well, I haven't looked inside the airbox for long enough to be embarrassed about it. 😊
Enigma
Enigma
East Tennessee Mudder
366
838
Rocky Top
View attachment 317346View attachment 317347
Thanks for the pics. I understand the problem now. I think this was the cause of one Talon owner getting dirt into the engine and having to replace the entire engine (honda warranty and dealership paid the costs). Soooo, should we Loctite Blue these bolts after tightening just to make sure?? What do you think?
64,057
Lock tight won't hurt.
Make sure you use something to pinch the threads flat as close as you can to the nut.
This issue would not have caused any dirt to enter. It's a internal part inside the air box.
Really, I'm not even sure it's purpose.
PapaC
PapaC
55
334
W. Wa
Yeah, I think I’ll just do it. Just means if it ever (hope not), goes into a dealer for anything they’ll check all recall/service items. Or I’ll tell them going in that I checked, and the threads were flattened. ;)
Elkhunter
Elkhunter
345
453
Minnesota
Checked my vin and my machine was in the recall. I’m snowbirding in Arizona for a couple months and go on rides at least once a week so this morning I thought I should check those clamps and I’m glad I did! Both were finger tight and about 5/8” between clamp openings. Tighten them down to about 3/8 and took a needle nose and buggered up the threads some.
Dankathy
286
822
Do you use a filter minder?
5,060
22,704
No, I don't. My first filter check was at 1066, the stock filter was spotless. My next check was at 25xx and it was still spotless. On that check, I was in a hurry and the airbox cover was dirty, I didn't want to remove the storage box and I had to lean over between the seats to remove the cover. Doing so, I bumped the cover against the body which dropped dust around the intake air horns, that made me think that I had an airbox leak. After checking everything over and realizing what had happened, I swore to never remove the cover without hosing off the entire area. Like many others, causing myself unnecessary problems by being in a rush.
The reason I don't have a filter minder is that I'd have to drill a hole in the airbox cover, adding a potential point of failure. A bit OCD but that's the reason. Since the stock filter is so well protected by the Uni pod prefilter, I don't see any need for a filter minder. But it would tell me my prefilter is dirty, again. 🤔
For the curious, details for Hondabob's snorkel and pod filter idea are linked in my sig, including the part numbers needed to make one, along with other basic Talon info.
