Currently trying to figure out if I want a light bar up front or some cubes. Will either go with Rigid or Baja. Any recommendations/thoughts?
I love my Xbright mirrors with lights, illuminates the dar areas in the front sides so you can see when turning at night and you can run them ridding behind someone with out blinding them.Currently trying to figure out if I want a light bar up front or some cubes. Will either go with Rigid or Baja. Any recommendations/thoughts?
The location of your light bar would last like a fart in the wind where we ride, we ride in a lot of brush and low hanging trees.
The bar is about 2.5" below the roof, and similarly lower than the cage. I haven't so far, and don't plan on running the cage and roof into solid objects. If I screw up and do that, I'm thinking the cost of a new Nilight bar (currently $149) won't be all that high on the "Oh S__t" list compared to windshield and frame damage.The location of your light bar would last like a fart in the wind where we ride, we ride in a lot of brush and low hanging trees.
You have to ride here to understand NW AR.The bar is about 2.5" below the roof, and similarly lower than the cage. I haven't so far, and don't plan on running the cage and roof into solid objects. If I screw up and do that, I'm thinking the cost of a new Nilight bar (currently $149) won't be all that high on the "Oh S__t" list compared to windshield and frame damage.
Good point. Alternately, (and a lot less work for me) you have to ride here to understand Nevada's high desert!You have to ride here to understand NW AR.
What length bar and what mounts?
It's a 54" Nilight. LinkWhat length bar and what mounts?
