P1K5Dave
Asking here because the guys over at TundraTalk aren't helping, and I know we've got some good electrical guys here.
The short question is: What do you make of a relay that clicks on and off while the switch it's connected to stays in the same position?
My 2014 Tundra has been signaling that my driver door is open as I drive down the road. So I replaced the door jamb switch, and it didn't fix it.
I was able to drill a little deeper by sitting in the parking lot with the door open, engine off, key in the accessory position. I could then push and release the jamb switch, and it would show the door opening and closing. Good...
But then I held the switch in the door closed position, and after a few moments it started freaking out and showing door open/door closed intermittently. I could hear a relay in the dash clicking on and off, even though the switch was held in one position.
My first thought is a short in the line between the switch and the relay, but I wanted to know if a faulty relay could act like this (?)
