P500 Relay buzzing issue
32lakes
32lakes
12
52
Star Valley, Wyoming
2017 P500 with one of the blue relays in battery/fuse box that just buzzes sporadically. Engine off you can walk out to it and hear the relay buzzing constantly or it will be on/off buzzing/energizing. I pulled the one that was buzzing and swapped with one of the others. No change. It cranks and runs fine. No other issues but that one relay constantly being energized. Ive looked and looked and cant seem to find what relay do what and what positions they are in when attached within battery box. Im thinking it might be fuel pump relay position but not 100% sure. Anyone else run into this issue?
208,725
I don't have a clue, hopefully some one will be along that can help.
Reactions: Smittyp
32lakes
32lakes
12
52
Well i went back outside and took another look. No key in the ignition/Not running and I turn the headlight switch to off position and it quits buzzing. Turn the switch back to the on position and the buzzing returns. I guess ill just keep it in the off position until I crank it. Then turn my headlights back on.
Reactions: Smittyp
208,725
My plumber guess would be bad ignition switch not turning off the key on part of the ignition. DO NOT run out and buy a ignition switch on my plumber guess, an expert will be along in due time.
Reactions: Smittyp
32lakes
32lakes
12
52
Yeah id say that is a good guess... I may shoot some contact cleaner down it tomorrow and see what happens. That is until someone else chimes in and verifies your good guess. Thanks
Smittyp
Smittyp
595
4,070
Morgan co. Tennessee
I’m no expert either but I’d start at the ignition switch too
208,725
If you try that, I would disconnect the battery first and let it dry out for a few hours before reconnecting the battery, I'm a plumber, so I only know a couple things.
Reactions: Smittyp
