P1000 removing dash
rstrandy
Rapid City
This is the easiest way to fix drafty gear shift levers on the Honda Pioneer 1000. All you need to do is remove the safety warning plate, use a cut off tool to create an opening and its very easy to see how to insulate the shift levers. Foam rubber works the best. Reinstall the safety plate with the warning data reversed and use the plate to mount your GPS, light switches etc.
Reactions: Lady01
