P700 removing rear sway bar
Lynn
Lynn
263
134
Yakima,WA
Has anyone removed the rear sway and gotten better traction particularly in the snow in rough terrain ?
I removed mine. Much much better. I highly recommend it.
It will ride smoother and get much better traction.
Reactions: ch33br0h
Some people tie it up instead of removing it. I tied mine up and tried it for a week and then removed it for the weight savings.
69,054
I took mine off when I went to windrock and really thought it did well. But here in Wisconsin were are trails are faster and very little "terrain"
I reinstalled it as it does handle better at higher speeds and takes a lot of roll out.
Lynn
Lynn
263
134
Yakima,WA
Thanks for the forum Tflynn. It was very helpfull. The sway bar's coming off tomorrow. I'm sure the more articulation in rough terrain and snow the better traction I'll get.
Tflynn
Tflynn
Not a liberal
2,501
3,831
Northern California
Glad you found it helpful. I look forward to hearing what your results are
REBrider12
5
10
North Carolina
For anyone still viewing this thread check out my video on removing it and difference in articulation.
44574938 0397 4408 8686 D04A13CF4982
livefromthetree
livefromthetree
It was a damn good ride. Seriously good.
466
1,309
Mount Vernon Indiana
Good job with the video. I will save it for showing the seemingly hundreds of questions (including my own a couple years ago) that show up here and on the FB groups asking why remove the bar.
BUT I also need to know what you did for behind the grill lighting that you can see at the end of the vid?
Reactions: REBrider12
REBrider12
5
10
North Carolina
They’re are small 3m sided LEDs that I wired into a switch from my accessory bus bar. I had to disassemble the front grille to get them up in there. Basically sitting in front of the radiator shining downward.
Here are a few pics. Hope this helps
E2D7176B 9F4E 4E1A AC12 155DFA8A0AE3
6E84BA12 CC31 4DAB A287 B9AC14917537 8489AF2D 3E3E 4100 AD83 65BA997262C7 3BB3692D C1E3 4626 A828 C3AE1068C4DC 9564271E 0BEF 449B 8E2F BD2565321106
Reactions: livefromthetree
