P700 Replacement Battery
CommanderDave
Iowa
I'm looking for an upgraded battery for my 2017 700-4. Having difficulty finding one with the same OEM dimensions. The closest I could find is a Motobatt MBYZ16H (16Ah) with 240CCA. (Motobatt MBYZ16H 12V 16.5Ah AGM Battery). Does anyone know of a similar battery that will fit and has higher Ah/CCA ratings? Thanks.
swsebek
swsebek
2,854
5,835
pa
Welcome from Pa
@Deluxe700 used that battery and said it worked pretty good.Maybe he will chime in.
Reactions: Mudwing
Backwoods
Backwoods
35,712
361,543
Douglasville ga
Mine went bad after I had it 2 months took to auto zone matched it up with a glass mate battery that was stronger and can be deep cycled. My warranty would have covered it. But they wanted to drag it out so I just bought one.
CommanderDave
Iowa
Thanks for the response. Do you happen to have a brand and model number for the battery you purchased?
Backwoods
Backwoods
35,712
361,543
Douglasville ga
Autozonebrand gold their best one part number ETX 14.was 109.00 been about a month since I or so since I bought it I'm pleased with it.
Reactions: Mudwing
Steve-O
6
19
Findlay, Ohio
I had problems with my battery on my 2017 700-4 so I took it to a guy who works on Polaris and put a 160.00 battery in it GYZ series (prem) and then hooked up a lead off my battery by my seat so I could plug a battery tender into it without taking seat off. Like a lot. No problems thus far and I run a lot of accessories off it. Plow, radio, heat, wiper and light bar.
