P700 Replacing oil screen pioneer 700
sam61
ohio
I am trying to crack open the engine to replace the oil screen and was wondering if some of the steps in the manual can be skipped. Like when I removed the engine and I skipped removing the front bumper and gas tank. For example do I really need to remove the thermostat?
DRZRon1
DRZRon1
1,102
3,580
PA
there was a post where somebody did a diesel/kerosene flush and for the screen cleaned with splitting cases - just saying
U can skip steps like these
Hello_Darkness
Hello_Darkness
200
839
Just to the right of nowhere
The entire engine can drop out the bottom on the "cradle" it seems on. It has to be lifted up and back to clear the mounts.
The front diff is pulled foward to getting be front shaft off and the rear will slide off once you get the cradle loose
sam61
ohio
Engine is out and on the bench. I noticed when taking it out the manual called for taking a lot of stuff off that didn't need to be removed I'm just wondering if cracking the case is the same.
sam61
ohio
Think I found my oil flow problem
IMG 20240826 183427683
  • Wow
Reactions: WagginTail
sam61
ohio
No, I bought it new and this is the first thing I've done to it besides oil changes. Never been off the farm.
