P1000 Replacing rear drive shaft seal - any suggestions?
Herbie
Herbie
86
190
Richmond, TX
While cleaning my 2016, and removing the skid plate, I noticed the rear drive shaft seal has been leaking at the rear diff. I have the service manual, but want to hear from anyone that may have replaced this before, and can offer suggestions or recommendations.
want the easiest method to perform this job.
Thanks for your help.
1612314302167
TripleB
TripleB
11,777
100,215
Caryville, Tennessee
My front has been wet for over a year but I've never had to add any oil to it. Unless you're leaking enough to add oil, I wouldn't change it.
Stixato
Stixato
6
24
Mine is leaking from same place. Getting worse every ride. When I go thru deep water, water is getting in and diaplacing the diff fluid that is
dripping out more and more from that seal. I change diff fluid every ride which has turned into draining water and a little fluid and putting new fluid in again. How tough was it?
Wellzy
Wellzy
269
899
SW Wisconsin
My front seal was leaking as I found a drip on the bottom of the sub-trans. It was under warranty, dealer found the leak to be the seal and replaced it. It was only making an oily mess when the wind blew it onto the skid plate but it was sooooo minor, the level did not go down when I checked it. Out of warranty, I may have just topped the sub-trans off and not worried about it.
IMG 9134
Reactions: Lady01
Josh2021pioneer1000-5
Cocoa
How did you get that cap off to get to that seal
Stixato
Stixato
6
24
I got to mine too late. I changed the rear diff fluid after every ride until I figured out where it was coming from. Finally the gears expended and blew a hole through the bottom of the rear diff. I looked everywhere for a video of the process and never found one. I ended up finding a new OEM rear diff online for the $600 range and changed it out myself in 4 hours start to finish. I too have a 2016 P1k-5. The cost of labor would have probably been the cost of the new diff so I just did it myself.
Reactions: Herbie
Herbie
Herbie
86
190
Richmond, TX
Takes patience, tools, and time. This was done 1-1/2 years ago, so do not remember each of the steps. You will be working in a tight and confined area. Raise rear of Honda and put on jack stands. Remove rear tires. The rear diff needs to be loosened (remove bolts securing to frame) and moved back some so drive shaft can be pulled out. I took out bolts holding the upper and lower right rear control arms to allow diff movement. Can't remember if I did left control arms are not. I pulled out the right rear axle, but don't remember if I needed to or not.
1670987549195
Boot O-Ring removed to begin sliding boot back to gain access to coupling
1670987866906
I used a puller to get coupling out, and it pulled off and bent cover, so assembly was replaced. Would probably been fine reusing it, though.
1670986940702
This is rear of drive shaft pulled out of diff once it was pulled back. I don't remember if front of drive shaft was removed or not.
1670986749327
This is what bad rear diff input shaft seal looks like with cover and coupling removed
1670988577620
Seal cleaned up before removing.
1670988490566
Back side of removed seal. Note that the seal seals on the coupling.
1670988276978
This is diff input cleaned with seal removed.
1670987221476
This is coupling and cover removed. Plan on getting a new coupling/cover when replacing seal, as cover may get damaged when removing coupling from diff input shaft. The clip needs to be removed to take it out. May also need a new clip as this may be damaged removing. 1670987354387
