P700 Replacing the cigarette outlet with dedicated USB/Voltage model
Slackjaw
Slackjaw
293
462
Durham NC
Been eyeballing these units as a replacement for the cigarette outlet on 2019 P700.
Is the OEM outlet standard size? If so, this should be an easy swap right?
I understand that there is a factory type harness on the rear of the OEM, so I may need to splice some, but this looks much more useful to me. Thoughts?
Better options? Better models?
Reactions: Backwoods
208,728
Looks trick, wonder if they make on for dual batteries?
Slackjaw
Slackjaw
293
462
Durham NC
If the batteries are wired parallel, then it's still 12V.
You mean dual readouts? One for each battery?
I'm assuming they are isolated.
Maybe put a two way switch so you can swap between the two to view voltage.
208,728
Dual and isolated batteries.
208,728
Sounds like more wiring, I'm sick of working on Rooster, just maitence from hear on out! HA!
Slackjaw
Slackjaw
293
462
Durham NC
I'll probably be at that point soon enough.
I'm still not at the 1st service yet so it's full steam ahead. My wallet hurts....
Alan_Vander
Alan_Vander
1,547
2,751
rosepine,la
Thought about this one a while back but then i put a radio with usb plug on it. Not worried about voltage. But this would be an easy install.
MICTUNING Universal Rocker Style Dual USB Car Charger (for iPhone 6 6S Plus Mobile Device, Blue LED Digital Display Voltmeter Monitor Battery Voltage(Blue)) Amazon.com: MICTUNING Universal Rocker Style Dual USB Car Charger (for iPhone 6 6S Plus Mobile Device, Blue LED Digital Display Voltmeter Monitor Battery Voltage(Blue)): Automotive
