Reverse lights the hard way
scttwlsn45
scttwlsn45
64
357
53
Farmington, WV
Okay new member, first post here goes. Hope it helps someone.
So I’m coming over from an old Polaris ranger I picked up used. Since the Polaris wasn’t wroth a whole lot of time and money I installed accessories the quick and dirty way. I decided I wanted to treat this machine better than the old one and do things as right as possible.
Accessory number one was a 5 panel rearview because I hated the bubble mirror in the old machine
But this post is accessory number 2. Back up lights. So, I wanted the OE hard back panel so I had to go with the Honda roof as well. With both on they match up to one another so well it’s almost like it was made to fit together. The problem is I didn’t have any access to the roll cage from outside the machine, so normal install wasn’t possible.
I got the club store dual back up light kits and this is how I did it with the factory roof and hard back panel.
IMG 1828
Note the two hex cap bolts. I removed them and the brackets from the kit would fit there but the roof interfered.
IMG 1827
I needed a spacer to go between the roof and the bracket or longer brackets. I figured spacers was the way to go. So, I got a plastic cutting board from the store and cut it into roughly 1” x 1 1/2” rectangles. I marked and drilled slightly oversized holes (5/15” ish) and installed two blocks behind each bracket and bolted them in with some m6x 40 bolts and installed the lights back into the brackets
IMG 1829IMG 1830
All I had to do was tuck wires and run them down to the plug for the back up alarm
IMG 1833
Tools
4mm Allen
10mm socket
8 mm socket and nut driver
Something to cut the cutting board (I used a sliding miter saw)
Drill bit if the appropriate size (I made my holes a little sloppy to aid reinstall)
Plus the normal stuff pliers, screwdriver and etc
Thanks for the great ideas and a great product
Lochsa88
Lochsa88
44
154
View attachment 417710View attachment 417711
Tools
4mm Allen
10mm socket
I also have a 3 seater with same roof and rear panel. I purchased the kit long ago but never installed. Had been waiting to finish my rear bed rack, but may go ahead with light install as you have done. Appreciate sharing what you did and pics.
Hillbillytnt
Hillbillytnt
545
1,979
Ky
Looks good. That’s where I mounted mine. They are high and dry so they stay pretty clean but do cast a bit of a shadow rt behind the bed
IMG 0052
scttwlsn45
scttwlsn45
64
357
53
Farmington, WV
I was also thinking of trimming a couple inches off of the roof where the interference was and tapering it down diagonally to the corner to make it look facktree
scttwlsn45
scttwlsn45
64
357
53
Farmington, WV
Also if anyone is 3D printing they maybe could sell a few of these here and there
Mountain Whiskey
Mountain Whiskey
27
81
USA
Pro tip: DO NOT use your wife’s cutting board 😅🤣😅
You should have seen my wife when she walked in the kitchen and I had a bunch of chrome parts off my Harley stacked in the dishwasher. She just looked at me "So, whatcha doing there honey?" I was caught like a rat in a trap. Just said "Oh nothing..." as I was collecting my parts and heading back to the garage.
scttwlsn45
scttwlsn45
64
357
53
Farmington, WV
Hilarious. “Can you believe I was just getting ready to load the dishwasher and found all this junk in here? Must have been some kind of prank” 😂😂😂
