P1000 Rig Down!!!!!
sthomp54
sthomp54
375
I consider any loose bolts @ this point a dealer problem, seeing as how these things have been sketchy at best since the first 700's hit the road. I still can't get every unit to come in with the right number of bolts in the bag. We fortunately haven't had many loose bolts but several other stupid obvious stuff. The seat belt bolts are a dealer installed item, I find that no one taps these holes out before installing the bolts. Also those are the only standard size bolt on the entire machine. Took us awhile to find a tap since we kept trying to jam a metric one in it.
I've noticed some of the bolts on my 500 seem way over tightened. Usually these things are put on a with a calibrated nutrunner at the factory so not sure what is going on. I tried to take off my door latch assembly allen head bolt and could not break it loose, it was about to strip the head so I just left it alone...
Reactions: pct
walexa07
walexa07
396
381
Louisiana
I installed a winch on my P1000-5 this past weekend. The KFI mount requires you to remove 2 stock diff bracket bolts. One of mine was stripped. I think they overtorqued it at the factory.
Waylan
Reactions: pct
sporttrac4x4
sporttrac4x4
1,177
2,083
ILL.
I did notice that my pioneer 700-4 had some cross threaded bolt's on the seat belt that I had to fix because it wold rattle. I'm sure they may of did the same on the pioneer 1000.
Reactions: pct
HondaTech
Any allen bolt that gets torqued to anything is impossible to get loose, but it wouldn't be the first bolt we've had to fix because of over tightening. Our dsm seems to talk like maybe they dont use pre set machines for every bolt. So maybe the nut holding the wrench is the one whos over tightened
pct
pct
Lost in the hills
790
1,023
Letart WV
Well now I would think that at the top of everybodys list should be to check and torque all the bolts where can we fins the torque specs at
PioneerPete
PioneerPete
1,496
3,517
Chattanooga, TN
the threads should never be in the shear plane. it would not be designed that way. only way it shears in the threads like that is if the bolt was working its way out. you must have had a missing nut or a nut backed off.
Donnie
Donnie
102
146
SW Missouri
Yeah, definitely raised my eyebrow. I'm thinking a longer bolt to get the shoulder out there into the frame gusset for more meat. Then put a bushing over the threads so the nut can pull up tight.
PioneerPete
PioneerPete
1,496
3,517
Chattanooga, TN
I guess another possibility could be that the bolt was sheared by over torqueing the nut. In either case, I would consider it a quality control failure at the plant. glad it didn't get anyone hurt.
Reactions: pct
I'll have to go back and check but I think the threads where in the shear plane when I was installing the CATVOS. I may go get some grade 8 all thread or some metric all thread with a grade of 12.9 if I can find it. That would be a fairly inexpensive upgrade for a piece of mind. Of course, if this is the only one that happened then it may be a fluke.
PioneerPete
PioneerPete
1,496
3,517
Chattanooga, TN
I've designed and analyzed many structural connections. No threads in the shear plane. I would lose my s#!t if honda designed it that way.
PioneerPete
PioneerPete
1,496
3,517
Chattanooga, TN
P.S. I would not recommend allthread for that application. Needs a hardened bolt with threads on the end. Its ok if the threads go into the socket of the outside part, but they shouldnt extend into the space between the joined parts (the shear plane).
That's true, I gotcha. How about I order some hardened rod and thread it myself?
Reactions: PioneerPete
ghost
ghost
993
1,874
BC
I don't why I thought this was funny but it made me laugh out loud.
Educational too - I'll never forget that rule now : "No threads in the shear plane"
I'd like to think that we will find out what happened here but not sure if the Honda engineers will share what they find.
pct
pct
Lost in the hills
790
1,023
Letart WV
I think that the bolt failed because if the nut came off you would think that it would rip the eye on the frame out before breaking just saying
pct
pct
Lost in the hills
790
1,023
Letart WV
How about a pic of the bolt head on looking at the end of the break
283,533
If you put a piece of all thread though the A-arm the bushings will wear out faster the you can say POPO from being cut into by the threads.
Please see post 35.
283,533
Please see post 35.
You better get a tough die if your going to cut threads on a grade 12.9 rod I would make sue the die has a Rockwell hardness over 70 or it will be an expensive experiment.
Reactions: pct
That's very true. I may have to get the guys at the shop to handle that for me. It may be over my head.
Our shop that builds our equipment and started our company is MaTech in Salisbury MD. They also manufacturer LWRC weapons. They are for sure qualified, but I may have run out of favors.
All this talk over what is potentially a one time issue. Oh well, I guess I'll get back to work. Don't get off until 7pm.
Reactions: pct
