P1000 New rig overheated
67,170
Ya, that totally sucks.
Outside of burping the system, most are simple fixes.
The most recent one was a bent pin on one of the connectors.
Here is a thread to read through with ideas and how to test the system.
PJon
PJon
794
3,222
Arizona
Had the same problem with mine on first ride. Turned out to be the pigtail connector from the fan not plugged in completely on the inside of right front vertical frame tube. Right next to radiator.
Jerryg
Jerryg
12,114
96,129
NEPA
OOPS, no biggie right? Just overheated your brand new engine, so much for breaking it in easy,
Honda needs to get their s*** together.
T
TheProvider
7
34
Illinois
Check the fan control box under the drivers seat. A loose connection there ended up being the culprit on mine. Just got it back the other day.
Manjackbaja
7
10
Baja sur
Iv read trough all the overheating threads I can find no one has suggested removing the thermostat? I’m located in southern Baja with overheating issues and a fully functioning fan . 60 deg is the coldest ambient temps I ride in , do I need a thermostat?
Scoop
Scoop
5,191
20,510
  3. Talon R LV
Yes. Your engine is designed to operate at specific temperature, and a properly functioning thermostat is part of that system. If you are overheating, there are likely other issues (e.g., air bubble in cooling system, fan not turning on, etc.).
