P1000m5 Rims and Tires
Tray
Tray
5
Has anyone tried CanAm rims and tires yet to see it the offset and lug pattern are the same?
66,870
Welcome to the club @Tray,
Several have talked about it but I cant confirm anyone who has done it yet.
They say a 4/137 offset will match up just well with the Honda 4/136.
If you try it be sure to let us know.
bobbyhill
bobbyhill
Junior Moderator
1,271
953
Smithfield, VA
Welcome to the Club @Tray!!
272,156
@Tray Welcome to the club. The bolt pattern should work, more importantly is the lug design of the rims you are looking at, there are two basic types a straight taper and a rounded convex taper on the wheel and lug nuts. as long as the nuts taper match the wheel its should all be good, if not they will not stay tight and center correctly. Just an FYI, seen this happen to people in the past and the result was a ruined rim at the lug nut seats and snapped off hub stud waaay out in the boonies.
Tray
Tray
5
Yep, they bolted up. Had to drill the lug hole out to fit the 12mm
Reactions: bobbyhill
