Roctane 26" or 27" on stock wheels
240tt
20
Have name on and will wait for 2015 700-4. Pulling off stock tires and putting on Brute Force as need tires for that too.
Dealer had Roctane's on hand and liked the look and 8 ply radial should wear good for long time. Question is 26" or 27" on stock 12" steel wheel?
will a 27" rub any on front fenders and would the Pioneer power suffer much with the 2" taller tire. Figure safe with 26" but would like to at least get a couple mph more on top end and not much loss on low end. Know I will not go over 27" tire.
Re: Roctane 26" or 27" on stock wheels
Will 27"- 10 fit on the front?
I'm pulling the trigger on new tires as soon as I find out.
Hobb30
5
I have 27-9-12 on the front and 27-12-12 out back on mine no rub
I'll find out shortly if the 10s fit in the front, shop is putting tires on rims right now.
Re: Roctane 26
With no lift. 27x10-12 Will fit on stock front rims and have PLENTY of clearance at full lock. The 27x12-12 on the rear rims, rub a bit, if you mount them up front. I think it's the offset.
The tires have a 26.5" TRUE height.
Probably have the clearance for 29's with a 2.5" lift.
Right side
E7e3u4ah
Left side
Zeja9u2y
Reactions: Bowtech32
