P1000 Roll cage
O2bsmitty
O2bsmitty
298
659
Illinois
Can someone tell me if the cage from front to back on front section is same for a p1k3 as p1k5?
Penrod
Penrod
Sanderson, FL
I stopped by a dealer to check this out myself last week. From what i saw it looks to be the exact same. I wanted to see if the rear ROPS section could be taken off the p1k5 in order to use a top from a p1k3, it looked like it would work to me.
I see now you're more interested in the front section, I'm fairly certain those sections are the same too.
Reactions: O2bsmitty
Delton
Delton
Honda Fanboy
9,967
31,488
Middle TN
I could be wrong but seems someone said the 3p hard top had to be modified to fit front section of a 5p. Can't remember where i read that or even if it's true.
Hometeam
Hometeam
995
4,155
Normal, IL
Has to be cut out around the mounts for the rear portion I believe.
Yes that is correct! I have a Honda 3P top on my 5P rig. I fits good with a little trimming of the back corners. I also actually really like the way it looks on a 5P but that's always subject to personal preference!!)
pct
pct
Lost in the hills
790
1,023
Letart WV
Welcome for WV and yes it will work 100 5979no changes if you leave the rear cage off
