Rolled over, now weird back peddle sound
Many_Gs
Many_Gs
217
517
PA
  1. Talon X4
So after a tip over today, I let her sit for 20 or so before firing it up. It burned a little white smoke, which I assume is going to happen with the oil situation. After getting back on the trail I noticed a much louder back peddle sound. The engine braking sounded louder in the exhaust.
Everything seems to run fine but I am curious if there's anything that I should be careful of or check other than the oil?
What should one do after rolling it over? What should be checked?
There were no leaks or anything after the rule over so I have no concerns of losing any oil or coolant. I just find it weird that the engine braking or back pedal is definitely louder.
Engine and exhaust are all stock, all of my mods are into tires/tree kickers and various other add ons which aren't relevant to the engine.
Sent from my SM-N975U using Tapatalk
Many_Gs
Many_Gs
217
517
PA
  1. Talon X4
Turn it back up on its wheels. Let it sit for a few minutes. Start the motor and hammer down!
That's what I thought too, especially since I didn't see anything laying on the ground in a puddle! No oil or anything leaked, so I let her sit for 20-30 then fired it up. Still, weird back peddle or engine braking sound. Seems louder, guessing maybe the baffle could have came loose but the exhaust doesn't sound different driving.
TripleB
TripleB
15,264
136,408
Caryville, Tennessee
Yep something had to change. I have no idea what it could have been. Everytime I've tipped or damaged something, I start hearing all kinds of different(new) sounds. I think most of the time it's just because I'm paranoid from the mistakes I just made.
Many_Gs
Many_Gs
217
517
PA
  1. Talon X4
You said it was smoking white. That is burning coolant.
That was only for a minute or two after the rollover. It sat for 20 or so then started it and seen the smoke. After that, there was no smoking and seemed fine, other than that back peddle sound.
5,430
24,949
I think it's common for a short puff of smoke on startup after a tipover. Not something I'd worry about - no ideas about the sound changing.
Rayger143
Rayger143
3,096
27,190
Winfield, BC Canada
It's almost like a baffle has moved in your muffler. Maybe take it off and give it a shake? I had that happen on an old quad of mine.
Reactions: CID and Russ989
Russ989
Russ989
22,642
147,257
That’s what I was thinking.
Reactions: Rayger143
