P1000 Safety flag, safety triangle.
Robobrainiac
Robobrainiac
2,457
8,551
I did some searching on here and I did not see any posts regarding mounting of a safety flag or slow moving triangle to the ROPS. So I did some thinking and came up with a plan and I figured I could post it on here. I bought some led tube mounts and flag spring whip from Amazon. I bought the safety triangle and mount from tractor supply.
For the slow moving triangle I bolted the tractor supply mount to the Amazon led tube mounts. I wrapped electrical tape around the ROPS to get the led tube mounts secure onto the tube and just bolted it all together.
For the flag whip spring mount I used the led tube mounts spaced apart using large nuts. I had a longer bolt for the spring whip mount laying around so I used that to replace the bolt the spring came with. I spaced them to make the whip more sturdy. I used electrical tape on the ROPS to make the led tube mounts secure as well.
This is my mount I used for the safety triangle
This is the mount I used for the safety flag
This is the flag spring mount I used
IMG 20200804 185037 IMG 20200804 185042 IMG 20200804 185045 IMG 20200804 185032 IMG 20200804 185021
BWAF
BWAF
I get paid to pass gas
8,857
42,437
Carthage MO
View attachment 216786 View attachment 216787 View attachment 216788 View attachment 216789 View attachment 216791
I went with here but that should work
20181109 135234
JimmyA
JimmyA
1,644
5,503
Northeast texas
In Texas, the triangle is supposed to 6ft above ground! I riveted mine just above the Backup light, and trimmed the top to be flush so overhead limbs would not take it out
Reactions: Lady01 and Biteme
Robobrainiac
Robobrainiac
2,457
8,551
This is what I found on Missouri law
SMV EMBLEM — Missouri law requires that no
person shall operate on any public high-
way of this state any slow-moving vehicle
or equipment after sunset to one-half hour
before sunrise, or any other machinery,
designed for use or normally operated at
speeds less than 25 miles per hour, unless
there is displayed on the rear a base down
equilateral triangle of fluorescent yel-
low-orange film or equivalent quality paint
with a base of not less than 14 inches and
altitude of not less than 12 inches. Such
triangle shall be bordered with reflective
red stripes having a minimum width of one
and three-fourths inches, with the vertices
of the overall triangle truncated such that
the remaining altitude shall be a mini-
mum of 14 inches. Such emblem shall be
mounted on the rear of such vehicle near
the horizontal geometric center of the re-
armost vehicle at a height of not less than
four feet above the roadway, and shall be
maintained in a clean, reflective condition.
I placed mine high so it wouldn't be in the way of the bed. Technically my machine is faster than 25mph :p however the small town that I live next to that I drive into requires the triangle and requires a speed limit of 25mph.
Robobrainiac
Robobrainiac
2,457
8,551
I did the flag mount because on our vacation we are going to we are taking the pioneer to some sand dunes and they require the flag to be 10ft or higher from the ground.
t-bear
t-bear
NE OK
Zip ties to upper driver rear ROPS for my triangle. I had Jared at Dirt Road Fabrication add a whip mount to the spare tire/fuel carrier I bought from him.
Reactions: Biteme
Robobrainiac
Robobrainiac
2,457
8,551
On a side note
At the sand dunes in Michigan the flag is required to be mounted to the front of the machine. They also require a very specific flag we have to purchase on sight. It took some last minute modifications and a kind atv shop that was local there to get our flag properly setup.
BigMac
BigMac
48
92
Used the top existing bed screw with bottom plastic predrilled triangle opening. Got triangle from farm supply. Easy to remove just one screw. Had to use small Philips screwdriver to line up plate hole to to top existing bed mounting screw. Only has one hold down but should work fine on road.
StewB
StewB
663
3,071
Utah street legal is pretty flexible - horn, turn signals and side mirrors and you generally can drive anywhere except Federal Interstates and Salt Lake City.
So I have nothing to add to the Amish Triangle discussion (yes, I lived in Illinois and will always think of horse carts when I see one).
There are only a few areas around that require a flag, like Little Sahara and Sand Hollow, so I wanted a way to quickly attach and detach my flag as needed. I can also take it off when trailering.
I found a heavy duty ROPS clamp with a large enough diameter mount hole for my flag. Two crescent wrenches, one left handed, the other right, will install and remove in seconds. I loosely wrap a bungee up higher to reduce the stress on the pole at the bottom. Works great.
1690144362969
1690144470355
1690144513997
And yes, my flag is the Be Happy face. I'm a nice guy and want to spread peace and harmony.
If you don't like it, go f_c_ yourself.
