I installed the western version and experienced same thing. I installed fox shocks on front and added 2 extra inches of preload and it fixed the problem. I also set the foxes to stiff when i have the plow on.I just installed a Boss XT snowplow and now the front is sagging from the extra weight. Will Fox shocks help or do I need spring spacers? Thanks in advance.
Just my .02 but you can go to a steel shop and get some 2 in sch.40 steel pipe cut 1 in thick for about 5 bucks vs. 700 bucks for shocks.I just installed a Boss XT snowplow and now the front is sagging from the extra weight. Will Fox shocks help or do I need spring spacers? Thanks in advance.
I don't have a plow here in TN but I did put the spacers on all four corners and it's made one hell of a difference and I saved myself a lot of money.Just my .02 but you can go to a steel shop and get some 2 in sch.40 steel pipe cut 1 in thick for about 5 bucks vs. 700 bucks for shocks.
You'll need a spanner wrench. Use the wrench to loosen the top lock nut on the spring and adjust the prelaod with the bottom nut. Remember to tighten the top nut when you're done.How do you add 2" of preload? I have the stock fox shocks and feel I need to do this.
Once winter is done, do you remove the 2" of preload?
Does this shorten the life of your shocks or negatively affect them in any way? Maybe its better for them because of the load from the snowplow?
If your front end is sagging significantly, you're probably hitting the soft stop built into the shock more often that usual. Adding preload should improve your performance but you also have the option to install a higher spring rate spring to better support the plow weight
