P500 Seat belt bypass
Sprd69
Sprd69
40
180
Texarkana Arkansas
Hi all. Just wondering if anyone has done the seat belt bypass on a 520 and what did you have to do? Patiently waiting on my new 520 to arrive. Thanks in advance.
Reactions: rtn001
Tom_C
Tom_C
158
473
Virginia, USA
My 2015 doesn't have that sensor, but there is a little jumper block you can buy to plug into the sensor connector at the seatbelt connector thingy.
Kinlaw
Kinlaw
226
1,183
NC
I think the Club Store has what you need.
Bisley
Bisley
154
737
West Covina, CA
It's almost too easy. Remove the seat. Remove the push pins to take the driver side half of the plastic off. You can't miss the plug for the seat belt. The video shows a P500 and a wire buried inside. The P520 must be different because the wire is right up top. Literally please g & play. About a one minute job after the plastic is out of the way.
Tom_C
Tom_C
158
473
Virginia, USA
Thanks guys. I didn't know if the 520 was different than the 500.
It is, but it isn't. Anything above 2017 are basically the same as far as I have found. The 520 has a bit different engine and trans, and of coarse the tilt bed, but it's essentially the same machine from what I know.
Bisley
Bisley
154
737
West Covina, CA
So..
Are yall confirming the 520 seatbelt connector is the same as the 500?
Bonus if anyone can get me a 520 picture.
Yes sir, it is. I ordered one a couple months ago, works perfectly. Even e-mailed them to thank them for how easy that and the fan override went in. If I get a chance in a little bit here I'll grab a pic.
Reactions: rtn001 and Sprd69
Bisley
Bisley
154
737
West Covina, CA
Ok, first off, just so you know it's a P520. Here's the bed in the background and the decal on the bed lol.
IMG 20210726 191455815
IMG 20210726 191606002
Now, here's an overview of the plug installed. Then a picture of each piece, the one held with the included zip tie and the bypass plug itself. Notice how they are directly on top of everything, no digging around needed 😉
IMG 20210726 191519297
IMG 20210726 191525964
IMG 20210726 191532315
Reactions: Bmurray and Bigtee
Janesy
34
119
Ontario
Just remove the plastic from the seatbelt latch. Click the seatbelt into it. Remove the switch when it opens up. Lift and pull gently on the metal contact and it will come out. Reassemble in reverse. This will leave the connection permanently open and seatbelt will read connected forever. No plugs or cutting wires. Takes 2 minutes
IMG 20210726 171739
IMG 20210726 171739
bowhunterbill
bowhunterbill
420
1,301
Bozeman, MT
Can I ask ‘why’ do it?
For me it’s a habit.
BTW my seatbelt saved my life when my Dodge RAM was t-boned by an idiot who failed to take his epilepsy meds and hit me broadside between 40-50 mph.
The Green Goat
The Green Goat
2,253
16,626
Ohio
Because if I'm just zipping around the yard, doing work, getting in and out frequently...it's annoying.
Bisley
Bisley
154
737
West Covina, CA
Is it really any different than being on a diet bike without one or a cruiser without one? And yes, I have survived the car that pulled in front of my cruiser and threw me 30+ feet with not much damage to me.
Reactions: Mudder
bowhunterbill
bowhunterbill
420
1,301
Bozeman, MT
Difference? If I fell off a bike and it rolled over on me, it wouldn’t crush me or a passenger. But this is Montana- if a guy wants to not wear a helmet on his road bike at 80 and risk crushing his skull and scrambling his brain, to live out his life as a quadriplegic- it’s a free state and his brain to do whatever he wants.
Stay safe.
Reactions: Mudwing
182,118
To each his own and if I were working around the property and getting in and out constantly, the annoying thing would be not being able to go over 15 mph. I personally wouldn't override it as that would be my safety net to ensure I didn't. If going over 15 I prefer to have it on. I hit a hidden root one time doing about 25 and we went for one hell of a ride, machine was bucking like crazy and I was not in control for a few seconds there. Thank God for the seatbelt or I would've bounced my head off the roof and broke my frickin neck. FWIW
Btw, that was before I put WE on and the stock shocks just plain suck.
Reactions: Mudwing and Mudder
Sprd69
Sprd69
40
180
Texarkana Arkansas
Just remove the plastic from the seatbelt latch. Click the seatbelt into it. Remove the switch when it opens up. Lift and pull gently on the metal contact and it will come out. Reassemble in reverse. This will leave the connection permanently open and seatbelt will read connected forever. No plugs or cutting wires. Takes 2 minutesView attachment 285761View attachment 285761
Just wanted to say this is a easy mod. Thanks so much for the info.
Did this yesterday. Super easy. Thanks for the info!!!
futzin
futzin
4,288
31,780
Kentucky
A thank you to @Janesy. I will add that the screws are Torx 10s, and here's an extra pic: (P520)
20230130 135718
Reactions: Buggyman and Mudder
HiFive
HiFive
697
2,914
West Central Fl.
I did it for convenience around camping area but, nice when I'm in the woods stopped taking a break and a black bear starts easing up on me I have one less thing to mess with for a clean getaway!
  • Wow
Reactions: CID
