P1000 Shift Cable Adjustment
bigblue2101
5
12
Pennsylvania
Just bought a plow for my rig. While plowing I noticed that it was struggling to get into low sometimes.
Per research on here, I tried to adjust the shift cable. Accidentally moved the lever out of neutral when checking free play. Not sure if that matters.
Now that it seems centered, it lurches more than it ever did before. If under load when on light throttle, it will actually stall out if it starts to bounce.
I tried tinkering with the adjustment to get it better, but still lurches a bit and will stall occasionally. Is one turn of the nut a lot or a little.
Am I doing something wrong? It didn’t do this before I adjusted the cable. I’ve moved it so much I’m not sure where I started any more.
Reactions: sharp and BWAF
It’s been a long time since I had to adjust mine, but if I recall correctly, there was marks on each side of the housing of where it needed to be adjusted to. Also keep that box free of debris, including water. I just read where one member had a problem and when he opened the box it was an ice cube in it. And you’re up north...:)
bigblue2101
5
12
Pennsylvania
Thanks for your reply. I’m talking about the adjuster under the battery. It seems somewhat intermittent. I was just using it under load while in a small ride to check the woods and it stalled out. Never did that before I made the adjustment. 2wd/turf/4wd seem to work as expected with proper dash indication.
Reactions: BWAF
Oops, my bad there. I had the box under the dump bed, directly behind the driver in mind. :rolleyes:
Reactions: BWAF
bigblue2101
5
12
Pennsylvania
No problem on the drive mode selector.
I did already try the clutch reset, sorry I didn’t mention it though.
Any other thoughts?
Reactions: BWAF and sharp
bigblue2101
5
12
Pennsylvania
Anyone have anything else? It is still really bouncing around and my wife is getting pi**ed.
If all I did was adjust the gear shift cable, I should be able to get it back. If I moved the cable while it was free, do I need to reset the shift arm on the sub trans? I have the clutch update, I shouldn't have cooked the clutches plowing, I was sure to not operate the winch and drive at the same time (no 2nd battery yet).
Here is an example: Plowing snow last night under light throttle coming up to a mound. When the vehicle stops, without adjusting the throttle, the idle drops down to 4-500rpms for a half sec before recovering back to ~1000. Sometimes it doesn't do this, sometimes it goes lower and stalls.
Reactions: BWAF
bigblue2101
5
12
Pennsylvania
Ok, I think I figured it out. The issue was coincidental with my cable adjustment and plow install. For more context, it’s had a long crank on startup for a while and sometimes required a key cycle.
Regardless, it was the engine ground by the starter. I got a few tightening turns out of it. I also checked the other two, they weren’t loose, but gave them a quarter turn to clean the connection up.
Pulls out butter smooth now, starts right up and all is good. Didn’t seem to fit the common symptoms of a bad ground I found on here, so I wanted to make sure to report back if it happens to anyone else.
