Shift knob removal
wyogz
wyogz
11
23
Cheyenne, WY
  1. Talon X4
I have a 2021 1000X-4 Talon. Does anyone know how the shift knob is removed, it doesn't unscrew and I tried to pull it off also, I need to remove it to install an aluminum shift plate.
Reactions: TxDoc
P
PT1911
11
SE MN
  1. Talon X4
The shaft has flat flanges on two sides so it doesn’t really twist off. It does pulls straight off, but it is extremely hard!
lee
lee
Village Idiot
2,403
13,608
Springfield Ohio
Heat the knob. It’s a rubbery plastic and it will get softer with heat. Unfortunately you need to heat it all the way through to make it easy to remove.
Hawk53
Hawk53
485
622
Alberta Canada
Ok thanks. I have had mine off a couple times but a person could break some body parts when it releases. LOL
Thanks to all, heated the knob up and it pulled straight up and off. New shift gate on and looking good.
Those shift gates look great and really helps the alignment, no more partial engagements....👍
T
TheyCallMeOne
Forsyth, GA
I had the same struggle and wound up using vice grips and a tie-down strapped to the top of the cage to ratchet it off.
NMelkaholic
NMelkaholic
89
241
New Mexico
Just removed mine yesterday.... I used a small piece of plywood placed it on the dash under the knob and used a claw hammer and gently pried it off... came off really easy like that.
Reactions: tmbrcruizr and CID
ScottJ24
ScottJ24
68
196
Cresson, TX
Heat and a ratchet strap and it came right off. Here is a
pic of the shifter shaft. Good luck twisting it off.
20230304 114723
  • Haha
Reactions: CID and Hawk53
Sparks
Sparks
11
49
Northern Wiscosnin
  1. Talon X LV
I did the same, 2x4, open end wrench and a pry bar. Placed a nice fitting open end wrench above the pry bar and under the knob and it works well. Just take your time and let it slide off, a nice clean removal.
