P500 Shocks Installed
hondabob64
hondabob64
215
795
Louisiana
D40A0EED E7D3 456E 8256 78ECA35351A9
E6CF30A6 B0CA 4B00 B6F5 8ECCF505D29D
Got them on! Light bar is the last item then I’m done!
Todd627
Todd627
56,730
619,393
MI
Awesome @hondabob64 👍🏼
Reactions: Mudwing
208,728
I got no instructions
Looks at it closely and see if you can turn the top of the shock 180, you will have a lot more protection that way? Did your reservoirs come with rubber cradles to mount to frame? If not I would come up with something between the frame and reservoir and don't tighten the clamps too tight, you can ruin the adjustably of the reservoir. What kind of shocks are they?
hondabob64
hondabob64
215
795
Louisiana
No rubber anywhere. I’ll have to remove both & reverse them.
208,728
Just unclamp your reservoirs remove top shock bolt and rotate the top of the shock.
182,153
Chooglin came up with these clamps for the reservoirs, can't find the link though. The first pic is how he mounted his, I wanted a little more protection and went inside the frame. It's like they were made for this, bolt right up, fit great and can easily access the adjustment knob.
Reservoir ClampsReservoirs 1Reservoirs
Reactions: lee
208,728
  • Haha
Reactions: Mudder and trigger
208,728
View attachment 201543View attachment 201544View attachment 201545
All good installs, but I like the second picture install the best? Which one works the best for you?
182,153
The second and third pics are my machine, each side actually. Both are tucked inside the frame so they're somewhat protected. I just didn't like the idea of the hose clamps that were supplied with the shocks. They'd probably work fine but the clamps that Chooglin found just seemed a much better option and they weren't that expensive. Bolted up to existing holes, rubber sleeves inside the clamp and allowed for them to sit a little lower for access to the adjustment knob.
208,728
You find out where he got them?
208,728
I looked all over, even in my purchase history and can't find them. 🤷‍♂️ Some are set up for horizontal mounting and some for vertical, ordered the wrong ones initially if I remember right.
Which way did you settle on? I'm ole fashioned I keep a file in my office drawer for every thing I have bought for Rooster. I ordered new graphics from Walter and a vent kit from Ross, finally.
182,153
To use the existing holes in the frame you have to use the ones pictured. Couldn't begin to tell you how much I've ordered from Walter...a lot!
208,728
Did you end up horizontal or vertical? I had an idea and Walter hit it outta the park, good guy, he's my brother, ya know, his Dad adopted me on a ride we were on, HA!
