P700m4 Shocks, Spacers or High Lifter Lift kits?
Smith102420
14
39
Morrison IL
  2. 1000 6 Crew
Been having trouble deciding which route I want to take as far as getting clearance for 28" tires. Didn't know if spacers or lift kit would make it ride more rough? Does anyone recommend one over the other?
Glock21user
Glock21user
1,825
9,092
Livingston county, Mi.
To lift them properly to my way of thinking is a better spring and shock.
Using spacers works if all you want is height but does nothing to address the woefully inadequate stock offerings.
A slightly stiffer ride doesn't hurt these machines at all as they are too soft from the factory.
I did the P1K shock/spring swap and have never complained.
Good luck.
105,544
What @Glock21user said.
stay away from the lift too. Rougher ride and messes with the suspension geometry. Both of what u mentioned are a cheap and in most cases a temp way to achieve lift for bigger tires. Arms and shocks with pre load is the way to go.
Oh and …Pics Or It Didnt Happen!
Of your machine
WagginTail
WagginTail
1,476
5,456
SC
I could be wrong but I didn't think they made offset a arms for the 700? I had spring spacers on the front shocks of my 700 and they stiffened up the ride and didn't bottom out the shocks. I also had super atv bracket lift front and back. I definitely liked the extra ground clearance. I've read on here that the commander shocks are the way to go. A lot better ride and I think they get you 2.5" of lift.
20210418 164422
105,544
I could be wrong but I didn't think they made offset a arms for the 700? I had spring spacers on the front shocks of my 700 and they stiffened up the ride and didn't bottom out the shocks. I also had super atv bracket lift front and back. I definitely liked the extra ground clearance. I've read on here that the commander shocks are the way to go. A lot better ride and I think they get you 2.5" of lift.View attachment 297614
Yep they do.
Maypo
Maypo
12
35
Rogersville, TN.
What size tires are those. They look good.
Maypo
Maypo
12
35
Rogersville, TN.
The Super ATV arms are high clearance but not moved forward. Danny Duncan and Moorehead are the only ones making forward arch arms for the 700 This Dannys arms and no lift. 28x14x10
View attachment 349221 View attachment 349222
I can't seem to find Danny Duncan. I found a page selling clothes and one called Duncan racing selling quad parts but I didn't see anything for a pioneer 700.
Reactions: NewHere2
WagginTail
WagginTail
1,476
5,456
SC
I’ve read can am commander shocks work. Does anyone know what year machine they’d need to come off of?
@RB3offroad sells the kit you need to make them work. I'm sure they would know exactly what year and model can am would work
Reactions: osobad and Maypo
