Multi Shots from the trail.
63,068
How in da phuck did @TripleB do that?
If you've ever changed a tie-rod and not punched the retainer, they will eventually start to back out of the rack if you ride hard. It might take a while but it will eventually start to loosen up. @TripleB usually bends them so quick they never get a chance to get loose in the rack though!
JenElio
JenElio
82,773
717,723
Loxahatchee, florida
🤦‍♂️...... JAH!!!
TripleB
TripleB
20,995
182,952
Caryville, Tennessee
Is this about as bad as the trails get? Or are there tougher spots?
There is worse spots. V-notch is a tough spot but the worse thing that can happen is some body damage. There is plenty of death spots that worry me. I don't even try to video or take pictures of those. I just hope I make it.
WagginTail
WagginTail
1,655
6,075
SC
I kinda figured v notch was just a good spot to video. Any hills y'all don't even attempt?
63,068
I'm impressed, couple guys I ride with have LE's and if they get one tire off the ground there done. I told them I didn't think there i-4WD was working correctly?
Tell them to back up and throw their purse at it next time.
It doesn't like to slow crawl and creep like a standard locked diff, a little wheel speed and it does it's thing. Definitely takes some getting used to. I've never driven the LE Pioneer but have ridden with a few.
212,729
HA! There's not a scratch on there buggies, they would rather winch and stack rocks! HA!
