Side mirrors w/windshield
Honda4lifeKS
Honda4lifeKS
17
105
Kansas
  1. Talon R LV
What side mirrors are y'all using with a windshield installed?
Reactions: TxDoc
5,758
26,443
These are a really nice mirror if the lower A-pillar cage bolts are accessible, Tusk replaces the bolts and adds a small bracket that the mirrors attach to. The problem for me is that I have the SATV flip up windshield and the lower ROPS clamps sit right over where the mirror mounts. I had to use a conventional ROPS clamp that probably won't work with a windshield. Talon specific fit -
The brackets are small and to the point. The bolts come with spacers so they stand proud of the recess in the ROPS.
1709871673574
Vikes79
Vikes79
SKOL!
12,059
115,838
South Dakota
  2. Talon X4 LV
These work great on my P1k5 with windshield and soft upper doors. Maybe they work well on a talon as well?
KEMIMOTO UTV Side View Mirrors Fit 1.75 inch -2 inch Roll Bar Multi-adjustable Angle Side Mirrors Compatible with Polaris RZR Can-Am Maverick X3 Talon Pioneer 1000 Wolverine Kawasaki Teryx
https://www.amazon.com/dp/B08MXB6Q26?tag=sxsweb24-20
Reactions: Honda4lifeKS
bumperm
bumperm
1,931
6,829
Gardnerville, NV
These cost a bit more, but they include puddle and forward lighting too. I wrote below review on Amazon after installing them. Disclaimer: I received the mirrors at no charge - but the review, if a bit "flowery", is honest. The single negative is a small one, that being the forward-facing amber light is not independently aimable, so due to mirror positioning, on the driver side it will be aimed on the high side - (unless you are very short). Review (Link below):
First of all, these are very good mirrors. So good, it's almost like getting the additional lighting for free. The mirror mount is secure, clamping around the sides and back of the roll bar, leaving the front of the roll bar clean so this install won't interfere with the stock windshield mounting. The clamping action is similar to a pipe clamp, in that the two halves move together on interlocking rails, so they clamp securely without the need to fully encircle the roll bar tube, slick! Once secure, the mirror attach is by a separate ball and cupped clamp, similar to a Ram mount. This provides full articulation through a broad range - you will not run out of mirror adjustment or reach a point where the mirror won't hold firm to stay where you want it yet will still be able to swing out of the way to avoid damage on an impact (assuming you don't overtighten things - just tighten enough so it stays where you want it). Good engineering and good design - nothing not to like here!
One of my pics shows the included rubber strips used to cushion the roll bar clamps. I included this as there was only one wider strip included in the box, the instruction sheet showed two strips - I thought I was shorted one. On closer inspection I saw the parting line that allows the single wide strip to be separated into two.
This comes with a nice wiring harness and a two-way switch to select Off - Amber Marker - Amber + White downlight. If you prefer the "other way around" (Off, Downlight, and Both) you can simply swap red to white and white to red at each side connection. I probably won't use the harness for now, instead powering the mirror lights from my side pod lights that are mounted each side near the base of the windshield. Dang I'm glad I got these . . . I think you will be too!
Mirror link
20240830 165345 20240830 165328 20240830 165955 20240830 165858
Reactions: 500oneer and CID
rockremoval
70
182
I know this is a few months old but for those who haven’t done it yet I have a 2024 Pioneer 1000-5 with a super ATV flip up windshield and the Honda oem mirrors. No issues as the clamp system fits in a spot just above the flip up windshield clamp mount with no interference.
Reactions: Buck25
