P1000 SIDE PIECE 2.0
Jason W
Jason W
The Ginger Cracker
1,298
10,911
Western NC mtns, Marion
  1. Talon X LV
20240606 100254
20240606 100254
20240606 100248
20240606 100236
20240606 160500
20240606 100258
20240606 100232
20240606 100225
20240606 100220
Center console installed, rear reverse lightbar with club store harness, new storage setup, my blue big cooler fit perfect, roam box can shove there 45 day wait up their booty.
Gmrs mounted, ghost antenna inside,
Trail armor a arm skids still to come, HMF front bumper with headlight and hood exo/tail light exo over bed still to come.
New winch cable(correct length) is here
Going to increase my brake pedal about 1.5 inches to the left, I like to two foot drive in rocks and hills, pedal is so small it's hard to trade my right to left on it
My brother Malenwa service dog and Lucy loo, growing up FAST! 20240606 100229
KyGal83
KyGal83
9,614
93,570
Kentucky
Aww... look at that snoozy pup.
View attachment 431867View attachment 431867View attachment 431868View attachment 431869View attachment 431865View attachment 431866View attachment 431870View attachment 431872View attachment 431873
My brother Malenwa service dog and Lucy loo, growing up FAST! View attachment 431871
Good job! It’s looking good. I wish I had your energy & motivation. I still have not washed mine yet. 😆
Jason W
Jason W
The Ginger Cracker
1,298
10,911
  1. Talon X LV
Mud busters installed, I put MANY extra pins in the fender flares, barely enough came with them.
Tablet mount installed, I went with a 10 inch titanium waterproof tablet from lifetime trailmaps, got it all installed and I am very pleased, NOTE TO ALL, if you use there software, follow the instructional videos to the letter, dont get in a hurry, I definitely needed
20240608 115100
20240608 115051
20240608 115043
the training.
Jason W
Jason W
The Ginger Cracker
1,298
10,911
  1. Talon X LV
All truly left is the trail armor poly control arm skids. Not here till mid next week.
Noticed rear was down .75 inches from front, quick adjustment put rear .5 inches higher for cooler wieght
ToddACimer
ToddACimer
Pioneer 1005-2
3,812
16,231
Oshkosh, Wi
One suggestion for setting ride height, camber and toe, would be to set your machine to the correct weight for riding with your normal payload and passengers. To cut down on the whining, I used water softener salt bags. I did 600lbs across the front seat and a spare tire in the bed. 300 on the cushion and 300 on the floor
ToddACimer
ToddACimer
Pioneer 1005-2
3,812
16,231
Oshkosh, Wi
I just dont want to loose ride qaulity
There's a good chance you'll improve it. Unless you set the suspension with your normal payload and passenger configuration you really won't know how well balanced the suspension is or how much travel you have. It's really easy to have your ride height too low with the soft springs on these machines. If you really want good ride quality, swap out the progressive rate coils for a set of single rate springs to match your payload configuration
Jason W
Jason W
The Ginger Cracker
1,298
10,911
  1. Talon X LV
Well shat, brother and I was on brown mtn today, trail 1a which is rough as s***, finished it, rolling down 2 and i4wd light comes on, then check engine, then THE FULL CHRISMAS TREE!
stoped , found ground on battery slightly loose, battery I new had crapped out, barely started, rode 6 miles out on trail one no power steering.
Stopped at oriellys and grabbed a new group 16 agm battery, the factory battery lasted not even two months, BS ,the factory is junk.
New one on trickle charge,
What main grounds shpuld I check as well?
Backwoods
Backwoods
37,719
375,859
Douglasville ga
My last Honda got about 90 days out of the battery when new. I figure just like anything else , sometimes you get a bad one. Replaced it and never looked back.
Similar threads
