P500 Skid Plate Install - Rivnuts or Self Tapping?
futzin
futzin
4,129
30,680
Kentucky
Which have you done? Regrets?
I've done self-tapping into the tube frame, a few of which keep pulling out. Then again, I hear the rivnuts can spin, bolts break as well.
JenElio
JenElio
73,015
664,995
Loxahatchee, florida
I actually have a few self tapping screws in my skid but they are thicker than normal and have held up great for the last few years (on square tubing part)....on the round tube I through bolted the skids where accessible. I don't have a lot of experience with rivnuts so I'm no help there.
178,016
Probably Tek Screws. They're hex headed and way stronger than a standard self tapper.
The Green Goat
The Green Goat
2,157
15,952
Ohio
I just threaded the holes I drilled in the frame. I fully expected some of them to pull out by now since there aren't a whole lot of threads in that thin wall, but they surprisingly haven't.
My backup plan is rivnuts when they eventually let go. I'll probably tack them in place as well.
TripleB
TripleB
15,119
134,769
Caryville, Tennessee
I used self tappers 6 years ago. Ive had to replace at least half of them with rivnuts. A few every year. I've had to drill out a few of the rivnuts and replace them with new rivnuts. I had to go 1 size bigger on one of them due to rust. I'm assuming before long they will all be junk. Those weld nuts are probably the best option.
JenElio
JenElio
73,015
664,995
thanks, I'll look into those, not familiar . . .
I actually use #10 fine thread self tapping screws. I use them for commercial door hardware, I just happen to have them by the hundreds so it's what I use 🤷‍♂️.....#3 tip, I haven't had one come out yet. The screw head sinks into the Honda washer perfectly and doesn't really get beat on when it's rubbing on rocks and stuff. Probably have a half dozen or more like this. When my OEM bolts rust out or snap I just drive one of the self tappers in instead. Works for me 👍
futzin
futzin
4,129
30,680
Kentucky
In the round tube framing...?
Reactions: JenElio
JenElio
JenElio
73,015
664,995
I've considered this...
I'm not too familiar with the P5s but on the P1K the round tube on the outer sides doesn't really have a lot of support and my aluminum skids at first had a little bit of tension so I didn't trust self tappers on the thin walled tubes. I've since sleeved/reinforced them but I already had the holes so I stuck with the through bolts. Those got nylon locking nuts.
JenElio
JenElio
73,015
664,995
It's just on the outside, the main part of the skid is bolted to boxed tubing.
20220514 233445
20220515 184432
futzin
futzin
4,129
30,680
Kentucky
Green Goat is right; thin walls. Tighter threads sounds helpful...
Reactions: JenElio
lee
lee
Village Idiot
2,383
13,486
Springfield Ohio
I used X nuts and applied gorilla glue to them.
Then I used stainless bolts with anti seize on them.
On a side note, I think the zink plated hardware that all OEMs use have a rare phenomena where in some small percentage of cases the plating corrodes in a way that makes the bolt seize.
In my now 30 years of experience I have only one data point where a bolt was put in at a known torque but broke off at a much higher torque on removal.
Of all the strange things I have needed to explain and make a fix for I have not (yet) figured this one out.
When I do, I will fix it.
In the mean time I have used stainless bolts in non critical areas on my personal buggy.
The stainless has its own issues so I do not use it on critical applications like suspension, drive train and engine parts.
Reactions: TripleB and futzin
