P1000m5 Skid Plates on the 1000-5 LE
UKNB
UKNB
54
66
Fredericton NB Canada
Still waiting for delivery of my LE. So I'm reading up on all the forums here and I got to looking at the skid plate and noticed that it doesn't seem to cover the full width of the undercarriage. I also saw some pretty incredible gill pokes where the floor has been shattered by a penetrating log or stick hidden in tall grass.
Honda doesn't seem to offer full skidplate coverage.... are there after market add-ons to fill the voids or am I looking as a complete new system to get full coverage underneath?
Again... thanks in advance to all who take time to read these and provide their honest feedback!
sporttrac4x4
sporttrac4x4
1,177
2,083
ILL.
You would have to make it for the sides. Or buy a full coverage.
272,162
Your best and safest route is to get full coverage UHMW skidplates. The Aluminum on the LE as you pointed out leaves passengers floor exposed to hazards, and starts too far back. Trail armor makes an excellent set as does a handful of other vendors. See below.
P1000 - Jackal's P1000-5
Finished install
Alan aka Davinci
Alan aka Davinci
Mr. Meme Master
16,789
183,378
Grand Junction, CO
Take a look at SSS off road, they are expensive but will last forever. I have hit rocks with my little P5 on the skids that have stung my feet but have not left a scratch on the skid.
208,726
Finished install
Running the Trail Armor my self, slides great over rocks and logs
This is what you're looking for.. cheaper than buying full skids!
2016 Honda Pioneer 1000
IMG 3755
hibbert
65
81
CR
If I have the OEM skid plates as preinstalled on the LE, is there additional plates i can buy that cover the areas the OEM dont?
Is it just the 2 piece that JTW linked?
272,162
Those that JTW linked are supplemental to the OEM Aluminum on the LE models. They will definitely be the lowest cost option to provide protection to the floor board areas.
That said, I ride in very rocky terrain and after 2800 miles the Aluminum skids were severely deformed and 5 of the bolts in the main section were sheared off as was 3 more across the 4 A arm pieces. See photos below.
If you ride in very rocky terrain your best route from a durability and protection standpoint would be the 1/2" FUTV Ultimate UHMW skid plate set. They are not cheap but great quality rarely is.
20190813 110233
20190813 110218
20190813 110207
20190813 110203
20190813 110159
20190813 110152
20190813 110148
20190813 110141
FUTV UHMW skiplates replacement for aluminum....
20190702 193232
20190702 193013
This is good advice... go with a good 1/2” uhmw plate and be done with it!
hibbert
65
81
CR
Thank you for your detail advice. After reading the forum and sliding under the pioneer, I fully appreciate that I should do a full skid replacement.
I am considering one of two options-
Option 1 - $1369
9-Piece Complete Skid Plate Set in Aluminum or with 1/4" UHMW Layer, Honda Pioneer 1000 with 3/16" Aluminum layered with 1/4" UHMW
Option 2 - $934
In combination with 4-Piece A-Arm & CV Boot Guards, Honda Pioneer 1000 because I like the added boot guard protection.
I will also be shipping these out to Costa Rica so total weight is going to be a huge factor. I believe that plays into option 2 with UHMW being lighter and I'm assuming option 2 is also better from a price and function standpoint.
My main concern is installation - I am a proper divvy, have no access to a lift or jack and really don't want to be drilling holes.
Reactions: Mudwing
272,162
Option 1 - $1369
Option 2 - $934
Option 2 is the best route, every aftermarket skid will require some drilling and self tapping screws are provided. If you have a winch, fastest way is to run line up a tree at least 12 ft off the ground and winch the machine vertical for installation, it will balance on rear roll cage to stand up.
Optionally you can affix 2 tie down to top of roll cage at front and rear and tip unit over about 40 degrees and install that way, but I don't recommend it.
Reactions: Mudwing
hibbert
65
81
CR
No winch unfortunately :(
hibbert
65
81
CR
All P1Ks have those, they most likely just removed them for the picture.
If they fit a standard 1000 they'll fit an LE.
As noted above, I'm a proper divvy.
Thanks for your help!
Looks like the ricochet arm and cv boots protectors with the factory utv 1/2 inch is the best way to idiot proof things.
Reactions: TripleB
Tramguage1
Tramguage1
Texan
7,479
30,593
Somereset, Texas
  2. 1000 6 Crew
  3. Talon X
  4. Talon R4 LV
I have 2200 miles on my LE-5
I just installed the Trail Armor 1/2" full skids. The factory was showing some wear, The center crossmember was tweeked . I just spent 3 days at RRB and felt a LOT more comfortable on the rocks.
I think the aluminum is adaquite for normal riding, But not for serious rocks.
I always say better sliding on the belly then on the roof!!!
272,162
Looks like the ricochet arm and cv boots guides with the factory utv 1/2 inch is the best way to idiot proof things.
You don't need richochet anything with the FUTV ULTIMATE kit is comes with everything. Running it on my LE over 4000 miles, fits perfectly
Reactions: TripleB
thashane
thashane
49
128
norCa
Option 1 - $1369
Option 2 - $934
I have 3/8" factory utv, no regrets. Installed w.o a lift. I did use jack stands to hold up one end of the skid, while I bolted the other. I prefer the one piece wide mid section of the FUTV skid. But does come in a large box, so the others may be cheaper to ship.
I'm not a fan of drilling a new machine, but I feel alot better now than I did before.
This is my suggestion... should be a little cheaper shipping as they’re smaller pieces. And their warranty if phenomenal!
Use coupon code Thank You for 10% off
