Ok friends here it is! I used 2" electrical conduit for the smooth bends. I cut the OEM intake tube just before the resonators and it fits nicely into a 45 degree and then couples to the 90 degree which you see come out between the seatbelt and body area. At the top I wanted a scoop style inlet and couldn't really find what I wanted, so I used a 22.5 degree fitting to a 3" opening adapter to scoop the air. I followed up with metal hose clamps to secure it to the roll cage. I haven't driven it yet to see any performance gain yet. I do notice less intake noise obviously with it located up high. I wanted fresh clean cool air feeding the motor. I think this would work on the P-4 as well. The "scoop" is below the max height of the roof so clearance is a non issue.
