P500 Snorkel to reduce air filter maintenance
Chooglin
Made up a snorkel to reduce the amount of dirty air this thing sucks in.I have a pre-filter inside the box and a intake vent to draw air in to the box...................I think this should do the trick !!!
Snorkel 4 Snorkel 3 Snorkel 2 Snorkel 1 Inlet
68,409
@Chooglin,
It looks good for sure. Have you got any riding time on it? I'm interested in knowing if pulling air from the rear of the box, where a low pressure area is, will be good or bad! Keep us updated.
283,443
@Chooglin Pretty slick setup! :cool: Just don't forget and use your storage box for a cooler :p
Chooglin
@Hondasxs I also thought about the low pressure area in the rear, but I am hoping there will be less dirt/dust back there.
I took a short ride just to see if there was any noise reduction and it seems better but not by much !!
If the box ends up getting a lot of dust in it , I may need to figure something else out ,but i figure it has to be much better than the stock setup ,as far as the amount of dirt it pulls in to the filter...................will keep you posted as I ride more !!!
Reactions: Hondasxs
Chooglin
Ya ,that would not be good !!!.......actually ,my cooler sets just in front of the pre-filter , so as long as it doesn't spring a leak,I should be ok !
Reactions: Dp5hunter
