P1000 Snorkeled - P1000-5
Manwell
Manwell
803
2,439
A couple of weeks ago I vented the fuel tank, transaxles and radiator fan motor and yesterday added the snorkel. I used @joeymt33 details and suggested parts and pieces. Thank you sir for making it easy!
IMG 3332
IMG 3345
Under the hood:
IMG 3341
I trimmed and installed the stock pre-filter at the top of the pipe sticking a stiff wire through it and bending 90's on either side, covering it with the clamp. I have enough pipe left over that I can make one taller if experience dictates. I have a bit more customizing to finalize the fit, need a different Dremel bit than what I have to complete the installation.
Tigermark
Tigermark
Outside looking in.
Under the hood:
I trimmed and installed the stock pre-filter at the top of the pipe sticking a stiff wire through it and bending 90's on either side, covering it with the clamp. I have enough pipe left over that I can make one taller if experience dictates. I have a bit more customizing to finalize the fit, need a different Dremel bit that what I have to complete the installation.
Good job bro, looks good!
Now let's watch that video of @drfubar doing the rain dance and then we will have a deep creek to play in.
Haha, that looks great bud. You ok love the growl.
Signature:
QUOTE by Sharp, Where's Don? He's probably spray painting stuff lmfao!
Windrock1000
Windrock1000
2,539
9,664
Windrock, Tennessee
Under the hood:
Looks great.
Reactions: pct and Manwell
Pioneer_Jake
Pioneer_Jake
16
Lima Ohio
Looks awesome man. @joeymt33 is the man. His entire build is badass. I did notice you didn't mention venting the transmission itself. Im in the process of doing my install right now and want to make sure I'm not missing anything. Its both diffs, transmission, fuel tank, and radiator fan vent correct?
Reactions: drfubar
There is a cable adjustment box on the drivers side under the rear passenger seat or bed on the 1000-3. You may want to seal it up to prevent corrosion.
23216bf054dadadb2426a98acee23431
Reactions: drfubar
cschomber63
cschomber63
278
477
Beloit
Under the hood:
Is electronic stuff protected?
Jaredgriffin29
Jaredgriffin29
34
26
Sandrock, Alabama
I like what Manwell got straight up thru the hood. Do i really need to extend all my vent lines? Don't plan riding in the lake. Maybe up the the doors . But do i still need to vent my lines ? Hope I'm using the right terminology here?
E
elkguide
3,377
7,964
Vermont
If you're going to get in the water, definitely extend the vent lines.
