P500 Soft tires
L
leboyd
24
39
houston
(I seem to always jump on the forum every few months and have a lot of questions...)
My p500 has 27" aggressive marsh type tires (unsure brand/model). My ranch is in rock country - 4wd will only be used if the rocks are wet and slippery - never because I can't get through the mud. There's truly only about 5"-8" of soil.
To soften the ride, I literally have about 0# of psi. Yes, 0#. The ride is much smoother, even almost comfortable. But the aggressive style of the tires seem to be an over kill.
I was considering something less aggressive, soft, but still in the 27".
Any ideas?
Reactions: TxDoc
NTCPrezJB
NTCPrezJB
President of #NTC
100,360
897,077
Canton, OH
This is the best zero psi tire/wheel combo I have seen on the forum.
Mudder
Mudder
NTC Ambassador of Walls
11,313
84,046
I run Journey 350, 27 inch on rocky terrain, it has the Bighorn type tread. The lowest I’ve ran is 6 psi, don’t want to break a tire bead against a rock
. D0596744 63C0 478C A692 78634EDD739A
NewHere2
NewHere2
Village Idiot In Training
35,590
303,073
High Plains of SD
If you were to sand those wooden wheels crossways to the grain in the wood, would they be more aggressive? #NTC
SP82
SP82
101
356
CA
Hopefully you have beadlocks. I like the tusk terrabites. They have 8 ply and 10 ply versions. Weight isn’t to bad on the 8 ply , they have a light truck mud pattern. I have them on my p1000 and at 10psi they ride better than my oem tires. ( I have beadlocks) Traction is great in mud snow and rocky terrain. Have had it in deep sand yet but they few sandy washes we’ve got they seemed fine. Barely use 4wd just 2wd locked 99% of the time
NewHere2
NewHere2
35,590
303,073
High Plains of SD
.View attachment 278502
Mudder, do you run bead locks for continuous heavy hauling in the rocks? I'm talking Elk hunting.
Bomersteve35
98
307
53
Portland or
  2. Other Brand
26 inch rocktanes almost rub at full turn on 5+2 wheels. Twice the tread depth of the bighorns and they ride nicer than the factory tires
Reactions: NewHere2 and Mudder
Bomersteve35
98
307
53
Portland or
  2. Other Brand
We run the rocktanes with. Beadlocks. Tire shops near us want 20 a tire to mount utv and quad tires. Plus a beadlock I can patch a tire from the inside back at camp if I have to. Also it's nice in the atv trails when the tire is in the ruts leaning on the sidewall less worry of mocking a tire off the bead..
20210415 213932
105,305
How about putting some air back in those tires and get you some good shocks that you can adjust to dampen the ride to your liking and ditch the stiff as a corps stockers and be done with all the fiddle Farting.
Reactions: Mudder and NewHere2
Peter_72
Peter_72
792
6,526
Louisiana
I just installed a set of Maxxis Big Horn 2.0 running 6 psi and they are very squishy. They seem to just wrap around rough terrain. We don’t have rocks but we do have a lot of tree roots and they do great!
5B52A9F2 DBD1 4552 A548 CF6A1140FF0C
crewcabrob
crewcabrob
1,029
4,038
Omaha
I have 27" BigHorn 3.0 in size 27x11x14 all the way around with Tusk bead lock wheels. I run about 6-7psi and I can tell you they ride very nice and also conform around roots and rocks.
20210613 012019563 iOS
20210613 012025884 iOS
Since I run the pressure so low, the tread has a much flatter profile. At 10psi, the tire rounds quite a bit.
