P500 Soften stock shocks?
Dynamicfigure
31
107
WA
I know the answer to a better ride is aftermarket shock$ but... the 520 comes with adjustable shocks, by theory...
Has anyone bought the spanner wrench (if so where'd you get it, and which one) and then jacked it up and softened the stock setting to the softest ride? Was there any/much of a difference??
179,021
You can get a spanner wrench from about any power sports dealer or online. You can also use channel locks, just be careful not to booger everything up. Even then you're not exactly adjusting the shocks, you're setting the preload on the springs. It'll ride a little softer but you'll run the risk of bottoming out on whoops and such. Aftermarket shocks make a world of difference.
Dynamicfigure
31
107
WA
Yea, I am certain the aftermarket shocks will help but the admission fee to that amusement park is a bit high for me at the moment. I was curious if anyone here had taken the stock one's down that one notch yet & if so, what, if any, differences they noticed?
Dave75
Dave75
123
500
I don’t know about taking it down one. Going to the max is a big difference in a rough ride, did it for snow plowing. The easiest way to a just the shocks is to jack up the P520. The shock wrench works, but not great.
Mudder
Mudder
NTC Ambassador of Walls
11,660
88,058
87F4FD26 0E07 461A AD11 4C1C1D229743 FAFEC1C0 65D9 4AF6 AA70 76785A60ADAE
alloutdoors
alloutdoors
1,022
2,184
US
  3. Do not currently own
If you place a jack under the unit and get the tension off the shocks, switching the setting is reasonably easy with a good set of channel locks. Personally, I found the lowest setting to be more comfortable and if you adjust the tire pressure downward some it helps as well vs. running them at max pressure.
Bomersteve35
98
307
53
Portland or
  2. Other Brand
Ok so the metal adjuster does nothing to the shock or the way the shock works or acts. It does not change the valve inside the shock. All the adjuster does is change the preload on the spring. For light smooth gravel road farm driving set the shock up for the softest ride. For tight trails and moderate stuff go to the middle. And for hard driving over ruff stuff and the times it's off the ground go to the tightest spring setting. But spring rate and pre load will not change how a shock acts.
Reactions: Dave75
179,021
Careful with that stiffest setting. If you get it bouncing it's an absolute pogo stick and hard to control. Been there and it's not worth it. (No HOMO)
futzin
futzin
4,177
30,995
Kentucky
I'm away from my machine. What's the stock setting?
Reactions: Backwoods
skinnyman
34
76
ohio
I believe this would be a discussion to have with someone in the shock industry, preferable an engineer vs. a salesman, as you covered many aspects of a shock and its operation.
Bomersteve35
98
307
53
Portland or
  2. Other Brand
Oh no I'm no sales guy. But I used to own and drive a dirt late model and I have general understanding of shocks and springs. I haven't done the research on shock sizes but I think with some doing a guy could find the right shocks for about 100 each and use the factory springs. But is it really worth it. We don't ride our machine hard and my wife made some nice red seat covers and glued in 1/2 inch memory foam. And that made the ride much better.
Reactions: Splorin and Dave75
futzin
futzin
4,177
30,995
Kentucky
I think there are 4 settings and mine were set on the second softest setting when I got mine.
Took a look at mine. Seems same. Is there any point to change 1 click softer? I ride slow...but sometimes slow over rocks where I'd hate to give up clearance.
179,021
It makes it slightly softer but then you run the risk of bottoming out the shock. I kept adjusting mine up in the back as I was adding more weight until it was maxed out. Hit a tree root at speed and the rodeo began. It was so rigid that it just wouldn't stop bouncing and for a moment I was out of control. Immediately dropped them back down and eventually changed them out with WE's. The stockers are functional but that's about the only praise I'd give them.
115,790
Honestly, were talking stokers here!
the difference is so Little with that adjustment. Its like trying to ware all black to make you look thinner when underneath your still fat! Harsh way to put it but true statement. Listen to @trigger. he knows what hes talking about with those stockers, Hes lived through the good and bad. Theres bot much good with stockers tho lol. I had them on my P5 and my dentist liked me alot Lol. save your pennies and the heartache and get u a set of aftermarkets when you can. weather it be standard Elka’s ( your cheapest rout) or the plush WE And do it once!
