That is exactly what I did and at low speeds the ride is acceptable. The down side is there is not much ground clearance but I get by just fine.If you place a jack under the unit and get the tension off the shocks, switching the setting is reasonably easy with a good set of channel locks. Personally, I found the lowest setting to be more comfortable and if you adjust the tire pressure downward some it helps as well vs. running them at max pressure.
